blackrex93 Posted February 3, 2014 Share Posted February 3, 2014 I have an 05 legacy gt limited, i am getting to the point where i want to start building the car, but dont really want to keep the automatic transmission, what do i have to do and how much will it cost to swap to a 5MT or 6MT? Link to comment Share on other sites More sharing options...
MrHellrais3R Posted February 3, 2014 Share Posted February 3, 2014 deep pockets and someone who is very good at electrical. I've only seen it done a couple of times. I believe my friend is probably the only one in the country who has done it and properly eliminated all CEL's. It was still a PITA, and totally not worth it tbh IMO. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 3, 2014 Share Posted February 3, 2014 You'll find its not worth the effort or $$,$$$.$$ Buy a car with a manual in it. Or do the HEXMOD. See the tranny forum. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
hobo2701 Posted February 4, 2014 Share Posted February 4, 2014 trade it in for a manual .. life lesson learned Link to comment Share on other sites More sharing options...
discojon Posted February 4, 2014 Share Posted February 4, 2014 I looked into this fairly extensively and made the determination that it's not worth it. In a nutshell you have to change front wiring harness, pedal box, fab up a transmission cross member, change steering column, drivers door lock, center console, instrument cluster, and many other bits and pieces. It's not as simple as dropping in a 5/6 mt and calling it a day. The mechanical pats are fairly straight forward but the electrical isn't worth it. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 4, 2014 Share Posted February 4, 2014 Don't forget, CC still doesn't work, as far as I know. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
