Pavoni8297 Posted February 1, 2014 Posted February 1, 2014 I picked up a used spt cbe and I am going to spend some time polishing it before spring up here.... should I do anything to condition the inside? just wondering... going to use nevrdull and bar keepers friend.
CrowNaza86 Posted February 3, 2014 Posted February 3, 2014 You should be fine with just using bar keepers friend and elbow grease...don't go in circular motions. The inside? No, I nothing
underpowerd Posted February 3, 2014 Posted February 3, 2014 forget the wadding; mothers chrome to start will cut/finish much better/faster...come to think of it, that may be all you really need .02
GEE-OTTO Posted February 5, 2014 Posted February 5, 2014 I used Mothers and the power cone and ball on used Magnaflow once it worked great then I sprayed one one can of clear coat (Rustoleum) on it to seal it up ahead of the salt season. I would polish the cans and paint the y-pipe black to protect it better.
Pavoni8297 Posted February 9, 2014 Author Posted February 9, 2014 I have been using that and it works great!! There are some scratches that I am dealing with. Have been hitting the area with a fine wire brush on a drill then the nevrdull.....really its the tips and can backs...... I must not be OCD with areas that aren't easily seen
