relative4 Posted January 29, 2014 Share Posted January 29, 2014 My windshield washer used to spray about halfway up the windshield. Now it only sprays up a few inches. Not cool in the winter. I cleaned corrosion from the connector at the pump, checked the voltage there (12.0, fine), checked the hose for pinch points, blew it out with compressed air, replaced the fuse, and finally replaced the pump. I used an aftermarket pump, which required me to cut off the stock connector and rewire, thus eliminating remaining connector corrosion from the equation. Nothing made any difference. I'm wondering if maybe the circuit, though pushing proper voltage, can no longer handle the current required. Anyone seen this? Link to comment Share on other sites More sharing options...
JmP6889928 Posted January 30, 2014 Share Posted January 30, 2014 Try hot wiring the pump directly to 12V and see if it pushes the fluid further. If it does, then you have a voltage drop somewhere, most likely the switch itself. Link to comment Share on other sites More sharing options...
relative4 Posted January 30, 2014 Author Share Posted January 30, 2014 Thanks! Is it OK to hook it straight to the battery with the car turned off, or could that burn up the pump? Link to comment Share on other sites More sharing options...
relative4 Posted January 30, 2014 Author Share Posted January 30, 2014 Sigh, a cracked hose was dumping half the fluid on the hood liner. Inexcusable that it took me so long to find it. I suck. Link to comment Share on other sites More sharing options...
hadvw Posted July 7, 2015 Share Posted July 7, 2015 Sigh, a cracked hose was dumping half the fluid on the hood liner. Inexcusable that it took me so long to find it. I suck. Just wanted to say thanks for this - really helped me narrow down my search. I had the same issue last week with my '05 (115k miles, NorCal, so heat, not cold, causing the aging). The hose going from the 1st to the 2nd nozzle/sprayer literally ripped in two as I turned it a little to see if there was a tear (after seeing a bit of water seep down). Symptoms: water was only spraying 4-6 inches up the windshield, and only 1/2 sprayers on the back (wagon hatch) were producing any water. 6' of 5/32" ID Prestone brand hose from Kragen (like $4.xx) later, and it's all good. 6' of hose was about 12-16 inches more than needed to replace everything under the hood (starting from the 90-degree elbow at the edge). I replaced every piece, including the ones going to the nozzles, etc. The "mist" option (pulling on the stalk, instead of pushing the button) seems to have mysteriously stopped working, but pushing the button works better than it ever has.. Link to comment Share on other sites More sharing options...
relative4 Posted July 7, 2015 Author Share Posted July 7, 2015 Pulling on the stalk isn't supposed to mist, it just gives you a single swipe of the blades. All is well. Link to comment Share on other sites More sharing options...
hadvw Posted July 9, 2015 Share Posted July 9, 2015 Pulling on the stalk isn't supposed to mist, it just gives you a single swipe of the blades. All is well. Yeah, I forgot about that somehow. The difference between "I need wipers, brain just does it" and "now, let me think about exactly how I use the wipers and test to make sure that everything is working as it should". Thanks for the reminder Link to comment Share on other sites More sharing options...
robertsm99 Posted July 21, 2015 Share Posted July 21, 2015 I think I ahve the same problem at least with the pressure of the pump. Haven't had a day to look under the hood to see if there's a leak or if the motor and pump are going out. If it is the motor and pump what exactly do I need to replace it all? Found this stuff, is it just parts 16 & 17 that I need or do I only need one of them? http://www.subarupartsamerica.com/parts/2008/SUBARU/Legacy/GT%20spec.B?siteid=216122&vehicleid=201802&diagram=7524430&diagramCallOut=16 Thanks. Link to comment Share on other sites More sharing options...
robertsm99 Posted July 21, 2015 Share Posted July 21, 2015 Never mind actually. The hoses at the junction of the hood have eroded and it's leaking there, so ordered the entire hood assembly from dealer, only about $30, hopefully it won't be too difficult to install. Link to comment Share on other sites More sharing options...
lazybummm Posted May 30, 2021 Share Posted May 30, 2021 Just wanted to say thanks for this - really helped me narrow down my search. I had the same issue last week with my '05 (115k miles, NorCal, so heat, not cold, causing the aging). The hose going from the 1st to the 2nd nozzle/sprayer literally ripped in two as I turned it a little to see if there was a tear (after seeing a bit of water seep down). Symptoms: water was only spraying 4-6 inches up the windshield, and only 1/2 sprayers on the back (wagon hatch) were producing any water. 6' of 5/32" ID Prestone brand hose from Kragen (like $4.xx) later, and it's all good. 6' of hose was about 12-16 inches more than needed to replace everything under the hood (starting from the 90-degree elbow at the edge). I replaced every piece, including the ones going to the nozzles, etc. The "mist" option (pulling on the stalk, instead of pushing the button) seems to have mysteriously stopped working, but pushing the button works better than it ever has.. bringing this from the dead because I am having same problems. and I saw the mist on the stick and pulled it too think it might mist maybe? Took a few second before I realized, other cars have the single wipe too. Link to comment Share on other sites More sharing options...
