abakja1 Posted August 24, 2005 Share Posted August 24, 2005 Can we make this a sticky?? I thought Id put this to get info and replies to what is most commonly used for fluid/replacement part improvements and intervals,..Possibly make it a poll for engine oil, front diff/tranny, rear diff, spark plugs, coolant, etc,.??? Oil: Every 3k miles with oil of your choice, Synthetics used after 10k miles by some. Popular choices are Mobile 1 for synthetic, I use Pennzoil for my dino oil,.. Front diff/tranny: Some use Redline 75-90w, get the 75-90NS which has no additives (cheaper alternatives are Quaker/Pennzoil synthetics), I will use GM Synchromesh as Ive used in my DSM and liked it,... Rear diff: Redline 75-90W,..NS not needed here,.. SparkPlugs: OEM NGK irridium replacements,...good for 60k miles according to NGKs claim, I figure I will change them yearly or as idle goes astray for daily driver,...Racers will check/change more often,...Go 1 colder range too??? Coolant: OEM replacement with OEM additive, no guesswork to be done here...You could use regular coolant, but read the manual about why its preferred to use OEM and OEM additive to prevent corrosion and add lubrication,....(anyone use Redline Waterwetter yet with OEM coolant??) Brake pads:Your choice depending on driving habits,..Carbotech panthers ft/rear. Endless SS (more expensive though, Axxis Ultimate rears (are cheaper alternative for rear),..can cross reference with aD770 rear pads from WRX to alternate rear pads from Hawk, etc,.. Brake fluid: ATE Blue/Yellow, Motul 600 Just my post to what is most commonly used as Ive browsed thru posts and "searches", may help to look here when wanting to Im currently at 3600 miles will change dino oil changed every 3k miles (did oil change at 500, 1000, and 3k so far), have ATE blue brake fluid, Carbotech Panther frts, Axxis Ultimate rear, Would you like to add your input and reviews to this post?? I would find it helpful personally and maybe it will help others to instead of reading countless "search results and posts",.. thanks Kevin Link to comment Share on other sites More sharing options...
Opie Posted August 25, 2005 Share Posted August 25, 2005 I'd add one note on the tranny fluid in the Auto's...I would stick to the genuine Subaru ATF Fluid as it has a special blend of friction modifiers specially chosen for the transmissions. There is a specific fluid formulated only for the 5EAT's, and another fluid formulated only for 4EAT's. Link to comment Share on other sites More sharing options...
melayout Posted August 25, 2005 Share Posted August 25, 2005 Opie are you sure, cause the Recommended Materials PDF specifies the same Subaru Item Number for both the 5EAT and 4EAT Subaru ATF Fluid?!!Recommended Materials.pdfRecommended Materials.pdf I keed I keeed Link to comment Share on other sites More sharing options...
Ed_T Posted August 25, 2005 Share Posted August 25, 2005 Dexron III is allowed for the 4AT but not the 5. Link to comment Share on other sites More sharing options...
AWD-Turbo Posted October 2, 2005 Share Posted October 2, 2005 Does the ATE brake fluid need to be changed as often as the OEM brake fluid? In other words, can it last 15k miles of hard, but not track, driving? Link to comment Share on other sites More sharing options...
abakja1 Posted December 3, 2005 Author Share Posted December 3, 2005 Does the ATE brake fluid need to be changed as often as the OEM brake fluid? In other words, can it last 15k miles of hard, but not track, driving? Probably not as often cause that is the purpose of a higher temp fluid,..You will still need to bleed every so often if your picky about pedal feel as well,..As for me, I really didnt change my ATE, but refilled and bled every year or as needed for regular driving,..Of course, every time you go to the track and again back at home,.. Link to comment Share on other sites More sharing options...
Opie Posted December 19, 2005 Share Posted December 19, 2005 Opie are you sure, cause the Recommended Materials PDF specifies the same Subaru Item Number for both the 5EAT and 4EAT Subaru ATF Fluid?!! Yep, I'm sure. 5EAT Specific Transmission Fluid is P/N: SOA868V9241 http://www.subaruchallenge.com/Wills/05/5EAT.jpg 4EAT & Older 3EAT trannies (and all current Power Steering systems) use this fluid, P/N: SOA868V9240 http://www.subaruchallenge.com/Wills/05/4EAT.jpg Both fluids have specific additives for their applications, a friction modifier is definitly in both...you can tell by their smell... Link to comment Share on other sites More sharing options...
