dgpro5000 Posted January 23, 2014 Share Posted January 23, 2014 2005 lgt here. Yesterday morning had to move my car. -20 degrees out and I stalled it trying to move it in the driveway. Didn't think much of it except later getting in my car I notice all buttons on the dual climate contol and radio do nothing except radio power and load and eject. Fast forward an hour and everything comes back on and 10 minutes after that everything back to doing nothing. So I unplug the battery hoping that would fix it. Now climate control is completely shut off and will not turn on. What's my next step? Tried ejecting my CD's too and pushing around on the dash. No luck. Do I check fuses and then start pulling apart the dash? Its nearly impossible to drive at the moment. Link to comment Share on other sites More sharing options...
dgpro5000 Posted January 24, 2014 Author Share Posted January 24, 2014 Checked fuses and only the #20 was blown which was a cigarette lighter. Replaced it and problem continues. Link to comment Share on other sites More sharing options...
dgpro5000 Posted January 27, 2014 Author Share Posted January 27, 2014 Bump! Please help. 0 degrees and no heat today . Link to comment Share on other sites More sharing options...
chato Posted January 27, 2014 Share Posted January 27, 2014 Mine did this once, but fixed itself not long after. All I can possibly add is to check your battery terminal for good contact. It's apparently not the first time this has happened to someone though: https://www.google.com/search?q=Site%3Alegacygt.com+heater+controls+not+working&oq=Site%3Alegacygt.com+heater+controls+not+working&aqs=chrome..69i57j69i58.9896j0j7&sourceid=chrome&espv=210&es_sm=91&ie=UTF-8 Link to comment Share on other sites More sharing options...
Max Capacity Posted January 27, 2014 Share Posted January 27, 2014 Yep, make sure the battery is in good shape and the terminals are clean and tight. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dgpro5000 Posted January 27, 2014 Author Share Posted January 27, 2014 Guess I'll check the terminals. I unplugged battery for an hour the other day and climate controls are completely out now. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 27, 2014 Share Posted January 27, 2014 After you clean them well and make sure they are tight and everything works. Then coat them with a good grease to seal out the moisture. Put the grease all around them and under them. Pretty much any grease you get fromt he auto parts store or tractor supply will work. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
dgpro5000 Posted January 28, 2014 Author Share Posted January 28, 2014 Cleaned up everything really well. Terminals look brand new. Still no climate controls. Gonna find a warm garage and tear apart the radio and check connections I guess. Any other options at this point? Link to comment Share on other sites More sharing options...
Max Capacity Posted January 28, 2014 Share Posted January 28, 2014 Do you have the service manual for the car ? http://legacygt.com/forums/showthread.php/wants-see-my-vacation-pixi-6216p10.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Shotokan1509 Posted January 28, 2014 Share Posted January 28, 2014 For heck of it try pushing around the face plate, when I took mine apart to install aux in the first power up was not fully snapped back in. The cold weather may have contracted the parts. Might not work but for 5 second free test, Id give it a whirl. Link to comment Share on other sites More sharing options...
subiestang Posted January 28, 2014 Share Posted January 28, 2014 Mine does this once or twice a year. I restart the car and everything powers back up. Link to comment Share on other sites More sharing options...
dgpro5000 Posted January 28, 2014 Author Share Posted January 28, 2014 So after driving for about 45 minutes today, got on a bumpy road and started fiddling with the volume. It started to adjust after about 10 seconds. Try turning on the thermostat nothing. 30 seconds later just hitting the button and it kicks on! Adjust it and turn on the defrost and now it won't adjust any more but at least its on. So thanks guys! I'll try pulling the radio when it warms up and look at connects. Not sure if cleaning the terminals helped or not but thanks for the suggestion cause they were pretty bad. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 29, 2014 Share Posted January 29, 2014 Back in the early day's with my 05. Sometimes the radio and HVAC would do funny things. Since I've kept the terminals clean, no issues. Good Luck, I hate car problems this time of year. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ScoobyGT15 Posted February 5, 2014 Share Posted February 5, 2014 Mine did this a few months ago as well. At least my radio did. I didn't think to check if the climate control was doing the same thing. But mine randomly started working again after maybe an hour or so. Annoying but to this day I still can't figure what happened to it Link to comment Share on other sites More sharing options...
