nstg8r Posted July 24, 2014 Author Share Posted July 24, 2014 Could that be resolved by changing the location of the camera? Just wondering if it expects it to be placed left, or right depending on the country and not actually dead center. The camera is placed where the stock camera would be. That wouldn't affect where the lines on the screen would be though. Link to comment Share on other sites More sharing options...
DrD123 Posted August 2, 2014 Share Posted August 2, 2014 So for the camera, is it only held in place with the adhesive tape you can see in the pic? Did you drill a hole to run the wire through, or is there a gap somewhere to use? I was looking at the Rydeen duo camera, but didn't know what I was looking at as far as mounting was concerned... is there a space between the trim panel and the trunk? Link to comment Share on other sites More sharing options...
nstg8r Posted August 2, 2014 Author Share Posted August 2, 2014 So for the camera, is it only held in place with the adhesive tape you can see in the pic? Did you drill a hole to run the wire through, or is there a gap somewhere to use? I was looking at the Rydeen duo camera, but didn't know what I was looking at as far as mounting was concerned... is there a space between the trim panel and the trunk? It's held in with tape, but there are slots to screw it in if you wish, the screws aren't supplied. You can see where I notched the plastic piece that the camera is attached to to run the wire. When you remove the trunk garnish piece to run the cable, it's held in by 4 nuts (from inside the trunk) and a single trim clip. I removed the trim clip from the garnish leaving it's hole open to run the camera cable through the trunk. The hole is more than wide enough for the cable, so I added a grommet so the cable wouldn't abrade. I then added a blob of butyl rubber I had from my headlamp projects to seal it so water can't get in. There is plenty of room behind the trunk garnish for the cable, but just be careful not to pinch it when replacing the garnish. The next part was the hardest, running the cable thru to the trunk. I ran it where all the other wiring goes, thru the rubber boot piece, using the good old-fashioned wire hanger method. I popped the two side of the rubber boot out first then ran the hanger thru it, taped it to the end of the camera cable, then pulled it thru. Link to comment Share on other sites More sharing options...
nstg8r Posted August 10, 2014 Author Share Posted August 10, 2014 http://legacygt.com/forums/showpost.php?p=4897453&postcount=12836 Link to comment Share on other sites More sharing options...
nstg8r Posted August 27, 2014 Author Share Posted August 27, 2014 Was hanging out with Perscitus and his brother Martin yesterday, so I finally got some video of my rear light mods in action... Link to comment Share on other sites More sharing options...
nstg8r Posted September 2, 2014 Author Share Posted September 2, 2014 And so it begins... Link to comment Share on other sites More sharing options...
GTEASER Posted September 2, 2014 Share Posted September 2, 2014 Was hanging out with Perscitus and his brother Martin yesterday, so I finally got some video of my rear light mods in action... It reminds me of a carnival. Do you have a popcorn popper and cotton candy maker in the back seat? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
nstg8r Posted September 8, 2014 Author Share Posted September 8, 2014 Link to comment Share on other sites More sharing options...
Perscitus Posted September 8, 2014 Share Posted September 8, 2014 Thanks for sharing Rob! Given the losses on the DynoDynamics rollers and the whp/wtq results reported with latest software suite.. that's 256-260bhp (@5.8-6K) and 250ft-lbf tq (@4.4K). So stock-level #s, which with the lean conditions and negative timing, is rather good. I bet if you sort both of those out, the intake alone would actually net a gain over stock HP/TQ figures... tune or no tune. Link to comment Share on other sites More sharing options...
nstg8r Posted September 8, 2014 Author Share Posted September 8, 2014 Thanks for sharing Rob! Given the losses on the DynoDynamics rollers and the whp/wtq results reported with latest software suite.. that's 256-260bhp (@5.8-6K) and 250ft-lbf tq (@4.4K). So stock-level #s, which with the lean conditions and negative timing, is rather good. I bet if you sort both of those out, the intake alone would actually net a gain over stock HP/TQ figures... tune or no tune. I've never seen my timing run in the negative, not sure why Rob saw that. Maybe he meant it's pulling timing due to knock. The knock he said is most likely from the ECU not being able to deal with the Takeda intake properly. Also, my fuel trims tend to be in the negative, so wouldn't that mean I'm running rich, not lean? Besides, they always seem to be within +/-10%, so I wouldn't exactly say I'm running too rich or too lean. I think he may have been referring to AFR and not fuel trim when mentioning the lean condition. We'll see what differences our new intake setup with the Volant filter makes on my car. We can plug in your ODB dongle and do some of our own logs with Torque before and after making the changes. Link to comment Share on other sites More sharing options...
nstg8r Posted September 9, 2014 Author Share Posted September 9, 2014 I checked my AFR and it hovered around 1.0 during most of my driving. It went down to .765 at WOT. Link to comment Share on other sites More sharing options...
Perscitus Posted September 9, 2014 Share Posted September 9, 2014 I checked my AFR and it hovered around 1.0 during most of my driving. It went down to .765 at WOT.That sounds in-line with mine and equivalent to about 14.7:1 'semi-stoich' to 15:1 'slightly lean' going down to 11.x:1 'slightly rich', but instead of AFR you were looking at its evil (European) brother - lambda: http://forums.pelicanparts.com/uploads17/Air+Fuel+Ratios1271770234.jpg Now, our AFR should likely only dip down to 12.x:1 (as commanded with my post-intake tune) but actually go a bit richer 11.x:1. I think this could be do to 10% ethanol in our fuel blends, while the ballpark targets above are for pure gasoline, pure diesel, pure alcohol, etc. If I factor in 10% ethanol, target AFR equivalent to 12.5:1 pure gasoline would be 11.96:1. I've seen measured AFRs as low as 11.2 or 11.4:1, which isn't bad. For our engines, 10:1 or 19:1 would be. Plus even though our AFRs can and are ok, the question is how hard long and short fuel trims must 'work' to achieve them. If timing is pulled, they are unable to get the job done by themselves. Link to comment Share on other sites More sharing options...
nstg8r Posted September 9, 2014 Author Share Posted September 9, 2014 Okay, but at 11.25:1 I'm running rich, not lean like Rob said. I'll have to keep my eye on it. Link to comment Share on other sites More sharing options...
nstg8r Posted September 24, 2014 Author Share Posted September 24, 2014 http://legacygt.com/forums/showpost.php?p=4936331&postcount=212 Link to comment Share on other sites More sharing options...
JT_36R Posted December 24, 2014 Share Posted December 24, 2014 I picked up a voltage stabilizer and I wonder where you put your in your bay. Can you take picture if possible? Thanks Link to comment Share on other sites More sharing options...
Perscitus Posted December 24, 2014 Share Posted December 24, 2014 I picked up a voltage stabilizer and I wonder where you put your in your bay. Can you take picture if possible? ThanksRight against the battery. Either directly behind it, by the strut housing or notched between the battery and the fender. Link to comment Share on other sites More sharing options...
nstg8r Posted December 24, 2014 Author Share Posted December 24, 2014 I picked up a voltage stabilizer and I wonder where you put your in your bay. Can you take picture if possible? Thanks It'll depend on which one you purchased. If you have the Eric Tioh unit, I wedged it in between the battery and the fuse box. If you don't have the battery sleeve like I do (part# 82123AG10B; Perscitus' '10 didn't come with one), then there will probably be too much room between the battery and fuse box. Link to comment Share on other sites More sharing options...
nstg8r Posted May 6, 2015 Author Share Posted May 6, 2015 So my friends, I think I'm nearing the end of my time with my Legacy and will be moving on to a newer, more luxury-style vehicle. Being that I won't get anything extra for all my mods when I trade in my vehicle, there will most likely be a part-out sale in the near future. Pretty much anything that isn't bolted down (i.e. LWCP) will probably be available. If there's anything in my journal that interests you now, pm me. Link to comment Share on other sites More sharing options...
jackal8788 Posted May 6, 2015 Share Posted May 6, 2015 I hope you'll still hang around the forum?? VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
Picky1 Posted May 6, 2015 Share Posted May 6, 2015 So my friends, I think I'm nearing the end of my time with my Legacy and will be moving on to a newer, more luxury-style vehicle. Being that I won't get anything extra for all my mods when I trade in my vehicle, there will most likely be a part-out sale in the near future. Pretty much anything that isn't bolted down (i.e. LWCP) will probably be available. If there's anything in my journal that interests you now, pm me. Bummer, to bad we never got together to tackle my lighting project. Link to comment Share on other sites More sharing options...
nstg8r Posted May 6, 2015 Author Share Posted May 6, 2015 Bummer, to bad we never got together to tackle my lighting project. Unfortunately, it's a back injury that has stopped me from doing any more mods to my vehicle and why I'm getting a new one. Link to comment Share on other sites More sharing options...
Picky1 Posted May 6, 2015 Share Posted May 6, 2015 Unfortunately, it's a back injury that has stopped me from doing any more mods to my vehicle and why I'm getting a new one. Understood, back's are tricky. I hurt mine about 7 years ago (L2 & L5) and I have never been the same and I refuse to get surgery. Link to comment Share on other sites More sharing options...
Zee199969 Posted May 6, 2015 Share Posted May 6, 2015 From time to time I get a pinched nerve in my lumbar area. Don't know when it will happen, but I know that it will and usually when I'm doing something pretty normal My "Build" Link to comment Share on other sites More sharing options...
s2baru Posted May 7, 2015 Share Posted May 7, 2015 Been hitting chiro myself these past 3 weeks. Bottom 2 vertebrate are pushed backwards pinching a nerve, so I understand your pain. Doing some "cupping" Friday morn, we'll see if that releases some tension Link to comment Share on other sites More sharing options...
nstg8r Posted May 9, 2015 Author Share Posted May 9, 2015 ... Link to comment Share on other sites More sharing options...
