LGT254 Posted January 16, 2014 Share Posted January 16, 2014 At the end of last week I started to hear a loud clunking noise that almost sounded like someone hitting a metal pipe with another piece of metal. It rang. The noise would happen when I was backing out of my driveway, parking lot, etc while hitting the gas. If I had the same steering input but was coasting I would get no sound. So I took it to my mechanic the drive shaft, axles, etc looked fine. He took of the drive shaft and started to take apart the rear section of the transmission. Sorry I don't know what this is called. He called me tonight and said that there is damage (see pics) to the center diff assembly. So my question is what are my options? Rebuild or new tranny? Do I have any other options? What's the cheapest way to go? And about the car. 2005, 83K, exhaust, tuned, 5EAT. I did a bunch of search and mostly came up with torque bind problems. Didnt see any like this. Thanks in advance. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 16, 2014 Moderators Share Posted January 16, 2014 Someone on the forum is selling a 5eat right now I believe... "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 16, 2014 Moderators Share Posted January 16, 2014 Yup, here: http://legacygt.com/forums/showthread.php/ma-ej255-longblock-and-auto-trans-219400.html In Mass. Maybe not too far from you? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
LGT254 Posted January 16, 2014 Author Share Posted January 16, 2014 Someone on the forum is selling a 5eat right now I believe... Do you think that's my best option? Link to comment Share on other sites More sharing options...
Max Capacity Posted January 16, 2014 Share Posted January 16, 2014 What is the cost of a rebuild ? Contact the parts guy's at Suburban Subaru in Manchester CT. Brett, bwelles@krausecars.com Karl, kmiles@krausecars.com Will, wphillips@krausecars.com They have helped me out with great pricing. I also have a tranny buudy that can rebuild yours if you need his services, he's in Windsor Locks CT. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted January 16, 2014 Share Posted January 16, 2014 $900 for a working tranny I guess is resonable, I'm not sure. But you still need to go get it, and have it put in. I think your diff can be rebuilt and then installed back on the tranny. The tranny is still in the car, correct ? I'm not up on 5eats, I know 5mt you can fix the diff with the tranny in the car. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 16, 2014 Moderators Share Posted January 16, 2014 Do you think that's my best option? You have as much info as I do. Scope out the cost of just buying a replacement and then get a couple quotes for repairing what you've got and go from there. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
LGT254 Posted January 16, 2014 Author Share Posted January 16, 2014 $900 for a working tranny I guess is resonable, I'm not sure. But you still need to go get it, and have it put in. I think your diff can be rebuilt and then installed back on the tranny. The tranny is still in the car, correct ? I'm not up on 5eats, I know 5mt you can fix the diff with the tranny in the car. Yes the transmission is still in the car. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 16, 2014 Share Posted January 16, 2014 So they can push the car back outside while you have the diff fixed then put it back in. You'll need to loo thru the "opposedforces" site from the link in the sticky at the top of the very first forum here. It will have a break down of the parts in the center diff. Make sure you have the correct year and model. http://legacygt.com/forums/showthread.php/subaru-oem-parts-catalog-online-exploded-views-opposed-forces-130411.html Do you have the service manuals? http://people.csail.mit.edu/ilh/vacation/ Also in the General Chat forum back a few pages there is a thread, show me your vacation pix, that has a link to all the manauls. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted January 22, 2014 Share Posted January 22, 2014 My apology, I'm late to the party. Your point of failure is the most common for the 5eat (stripped center diff input shaft gear teeth). You can buy the replacement parts new, usually for around $1000. The vacation pix are very clear about exactly how to replace everything. If you happen to have the time and resources, you can get a used, worn & shot 5eat for a couple hundred dollars, and pull whatever you need off of it. Where are you now with the repair? Lastly, how did you do this to the center diff? [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
