09LegacyDude Posted January 9, 2014 Posted January 9, 2014 So I have a long list of questions please help me with any that you might know. 1. In the morning especially when cold the clutch and transmission with shutter, this happens when starting from first and the shift from first to second. After about 3 shifts the noise and feeling is gone. What is going on? Also I always let my car warm up for 2 minutes before driving it. 2. On colder mornings the engine seems to make a rather loud tapping noise until it gets warm, is this normal? 3. My rpms drop to almost a stall when I get to traffic lights and come to a stop, this happens all the time. What might be the cause of this? Thank you for the help I really appreciate any advice.
GEE-OTTO Posted January 10, 2014 Posted January 10, 2014 1. Cold temps do that to some cars, have you ever replaced the fluid ? 2. Cold temps do that to most Subarus on really cold days, have you replaced the oil lately? 3. Go to the dealer there is a recall for this issue for the 08+ NA Subaru.
DonnyJagaru Posted January 10, 2014 Posted January 10, 2014 I didn't know about the last one. It happens to mine sometimes too.
GEE-OTTO Posted January 10, 2014 Posted January 10, 2014 Yeah I wrote a thread about this a few years ago. The dealer has a reflash for your stock ECU to correct the stumbling issues. Used to happen to my 2.5i when it was brand new all the time, drove me crazy! But its a quick fix at the dealer and free!
09LegacyDude Posted January 10, 2014 Author Posted January 10, 2014 thanks for the help. I have not changed the oil recently but I will get that done, and do I need to swap out the gear oil in the trans or the clutch.
DonnyJagaru Posted January 13, 2014 Posted January 13, 2014 Okay, mine only stumbles every once in a while so perhaps not the same thing? I don't want to take in to Subaru as they may "find" another problem. Is there any way to read the "firmware" rev on these cars? I have an OBDII reader and software.
Yamba6 Posted January 13, 2014 Posted January 13, 2014 So cold temps can make it seem like your car is slipping in gear until it gets warm? Is this correct? And the best thing to do is replace/flush the tranny fluid?
apexi Posted January 14, 2014 Posted January 14, 2014 Tranny fluid will have no impact on the way the clutch engages in my opinion. To me it sounds like the opposite of the clutch slipping, the disc is sort of sticking at first until it warms up a bit. Sounds like an issue with the flywheel or clutch disc.
GEE-OTTO Posted January 14, 2014 Posted January 14, 2014 When I had my 2.5i around 38K miles the pressure plate failed the dealer replaced it under warranty. It caused a ON/OFF feeling when shifting. Depending on your driving habits you may have worn the clutch to a point where the cold affects the time the clamping friction produced by the PP causes it to "lock up". You can warm it up and try the 5th gear test to see if it slips then. The fluid at such low mileage wont affect operation like apexi stated
GEE-OTTO Posted January 14, 2014 Posted January 14, 2014 Okay, mine only stumbles every once in a while so perhaps not the same thing? I don't want to take in to Subaru as they may "find" another problem. Is there any way to read the "firmware" rev on these cars? I have an OBDII reader and software. If at low speeds or approaching stop lights its stumble to 400-500 RPMS its the firmware. No way to pull the image unless you get a Tactrix 2.0 cable and ECUFlash/Romraider software.
Fast Eddie Posted January 16, 2014 Posted January 16, 2014 2. On colder mornings the engine seems to make a rather loud tapping noise until it gets warm, is this normal? After my 2000 developed this symptom, I learned that it's pretty common with these engines. If you go to youtube and search for Subaru noises, EJ25 noises, etc you will probably find your noise. Mine is piston slap and it's bad, but it goes away and the engine runs fine. If it's in the 40s it goes away in 30 seconds and if it's 50 or above you don't even hear it. It doesn't even use any oil. I do wonder about long term durability and accelerated wear. Apparently a lot of production engines have suffered from piston slap. Ford produced the "hyperkinetic" piston to address it; this is a hybrid piston with an expansion controller ring cast into the forging. It does work and is stronger than low grade cast pistons.
Wheelbuilder_25 Posted January 16, 2014 Posted January 16, 2014 I don't think it hurts longevity much. My Dad's 01 Forester has the cold tapping bit, and has done so for right about 250,000 mi. Still uses less than 1/2 quart in 3000k. My old 97 Outback did the same tapping thing for the 15 years I had it. (it was a low miles car anyway)
NickB34 Posted January 17, 2014 Posted January 17, 2014 I have problem #1 that you state. I figure at 70k miles and the way I drive that the clutch is on its way out. What's interesting to me is that it is somewhat inconsistent, I would say it is due to the weather, but my car is always parked in a garage. I'm sure I will need a new clutch before 80k... going to milk this one as long as I can.
09LegacyDude Posted January 27, 2014 Author Posted January 27, 2014 thank you guys for all the help. Here is an update, most mornings now the car seems to jerk and it feels like the clutch is chattering from N to 1st and 1st to 2nd. After 3 or 4 shifts the car is fine and does not display any problems. No matter how slow or fast I let out the clutch the car does the same thing.
09LegacyDude Posted January 28, 2014 Author Posted January 28, 2014 this is the second winter this had happened. Just this year it is worse. During the summer I never have this problem.
NickB34 Posted January 28, 2014 Posted January 28, 2014 I got pissed at my wife last week and dropped the clutch out of the driveway, car didn't really move but the clutch was engaged. When I let off the gas and the car started to go, I got the vaunted clutch stink. But, the stuttering has gone away. I'm guessing that maybe there were some deposits on the clutch or flywheel that I burned off. You may try and slip the clutch and see if that changes anything. Again, it could be a different issue for me as I've got a decent amount of miles on mine.
apexi Posted January 28, 2014 Posted January 28, 2014 That's what I was going to suggest Nick. There might be some stuff on the clutch disc or flywheel, and if you're already having issues I don't see the harm in trying.
09LegacyDude Posted January 29, 2014 Author Posted January 29, 2014 cool thanks guys, the car only has 35,000 miles on it. I have an extra warranty so if it goes I will just have subaru fix it.
GEE-OTTO Posted January 30, 2014 Posted January 30, 2014 That's what I was going to suggest Nick. There might be some stuff on the clutch disc or flywheel, and if you're already having issues I don't see the harm in trying. Never thought a 2.5i would be told to launch for any reason Its a win win!
NickB34 Posted January 31, 2014 Posted January 31, 2014 Issues haven't come back yet... I was confident that I would need to replace my clutch in the next 10k miles. Here's hoping it make it to at least 100k!
09LegacyDude Posted March 31, 2014 Author Posted March 31, 2014 Update: So I roasted my clutch the other day backing up a large hill, smoke, horrible smell the whole burnt clutch deal. My clutch has never felt smoother and no more shuttering. Thanks to everyone for the help.
