firepyro515 Posted January 4, 2014 Share Posted January 4, 2014 Crazy question, but is there an easier way to replace the fog light bulbs aside from removing the whole bumper? I have taken off the bumper before, but it is a pain in the a** and I am trying to avoid it. Link to comment Share on other sites More sharing options...
iNVAR Posted January 4, 2014 Share Posted January 4, 2014 Unless it's drastically different from an 05, you just go under and behind the bumper. Requires removing a few popits from the side (small) plastic undertray. Link to comment Share on other sites More sharing options...
bluesuby Posted January 4, 2014 Share Posted January 4, 2014 Unless it's drastically different from an 05, you just go under and behind the bumper. Requires removing a few popits from the side (small) plastic undertray. Have any pictures or shop manual diagrams? I've gone in from the wheel well liner. Not pleasant. Be mindful you don't pull off the ground wire connection before buttoning up the job. Link to comment Share on other sites More sharing options...
ehsnils Posted January 4, 2014 Share Posted January 4, 2014 I agree that it sucks replacing bulbs - there should be a law requiring vehicles to be designed to allow bulb replacement by an unexperienced person without tools at the roadside within 5 minutes. For ANY bulb in the whole vehicle. Link to comment Share on other sites More sharing options...
apexi Posted January 4, 2014 Share Posted January 4, 2014 fsm instructions Link to comment Share on other sites More sharing options...
firepyro515 Posted January 5, 2014 Author Share Posted January 5, 2014 Thanks, looks like i'm going through the under tray Link to comment Share on other sites More sharing options...
DonnyJagaru Posted January 6, 2014 Share Posted January 6, 2014 I swapped the whole fixture on both sides last summer. Its dead easy to do. Replacing bulbs must be easier. Yes, undo the bottom cover with the plastic "rivets" and you'll have easy access. Link to comment Share on other sites More sharing options...
