n0nps Posted December 27, 2013 Share Posted December 27, 2013 I kicked a Cat 420 code. I replaced the bank 1 o2 last year and it got me by. i just kicked it again on the way home from work. I need to replace my cat/manifold however the dealership wants 1200 for it. I would rather just put on an aftermarket high flow cat and header setup however i cant find one? Do any of you know of any? I was also thinking i could use the exhaust header off a 05 2.5i and high flow cat and do a cat back exhaust but then i would have to drill and mount spots for the o2 sensors which means i would most likely have to get a tune as well and maybe delete the o2s out. i am really stuck here would love all inputs thanks Link to comment Share on other sites More sharing options...
GEE-OTTO Posted December 27, 2013 Share Posted December 27, 2013 Find a used manifold for sale and buy it. All the option you mention are costly and the 05 setup wont work easily on your 07. Link to comment Share on other sites More sharing options...
n0nps Posted December 27, 2013 Author Share Posted December 27, 2013 I dont mind spending money if it is an upgrade, and i also dont mind extra work the 05 option might be my only bet if i am looking for the upgrade tho? Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 27, 2013 Share Posted December 27, 2013 There's a TON of stuff on ebay for 2.5i regarding exhaust. Simply search "2007 Subaru Legacy 2.5i Exhaust system" and there are headers, cats, crossover pipes, axle back systems, EVERYTHING you would need to put a complete system together and they'll already have your O2 bungs in them. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted December 27, 2013 Share Posted December 27, 2013 The 05 is a downgrade the stock 06+ EL manifold flows better than any 05 Stock of aftermarket option you may spend money on, forget that idea. There are reasons the 05 wont work, it isnt the same clearance from the heads as the 06+ so it will melt your steering lines, the stock location O2 sensors wont reach and youll have to reroute your exhaust (CBE) to mate to it. Your ECU will throw the same P0420 code constantly as the cat will operate at a cooler temp than it is programmed to like due to being farther away from the exhaust ports. You would cause yourself more headache, to put it simply, trust me I wrote dozens of threads about this issue. Second, your cat is rated to last as long as your car when mine failed Subaru replaced it free of charge, if the dealer is rejecting your claim go to another more competent dealer have them check it out and replace it. This same failure happened to me around 90K miles I thought I was screwed. IF they feed you BS go over to NASIOC or RS25.com and search for "Stock 2.5i header" youll be able to pick one up for under $250, bolt it on and go about life as normal or until you want a Rallisport header:) Link to comment Share on other sites More sharing options...
n0nps Posted December 28, 2013 Author Share Posted December 28, 2013 Thank you. The dealership said f your self. I found a magnaflow header for 600 and a local exhausr shop is going to make me a cat back for 150. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted December 28, 2013 Share Posted December 28, 2013 Wow you are going to spend 750 to throw the same code you are trying to fix, constantly? I now know why I got scorned all those years while toying with that idea Link to comment Share on other sites More sharing options...
n0nps Posted December 29, 2013 Author Share Posted December 29, 2013 Well in live in pa so the code has to be cleared. If I'm going to fix it I might as well replaced or with a new one second I want a cat back I don't need it Link to comment Share on other sites More sharing options...
GEE-OTTO Posted December 29, 2013 Share Posted December 29, 2013 I give up spend $750 to worsen your problems, then go to the dealer and pay him the $1200 to fix. or Buy a used manifold and solve your problems for under $300. Do with that what you like. Link to comment Share on other sites More sharing options...
