RedDawg Posted December 19, 2013 Share Posted December 19, 2013 Had one of the lines going to my ebcs pop off this past weekend (the red circled hose). Put the hose back on, zipped tied it down this time, but the CEL for P2096 stuck around. This happened a few months ago, same hose popped off, and the CEL cleared after about 2 days. Should I pull the battery terminal and let the ECU reset itself? http://i43.tinypic.com/ekhv0k.jpg Link to comment Share on other sites More sharing options...
Max Capacity Posted December 19, 2013 Share Posted December 19, 2013 The ECU will clear the code after 4 restarts of the engine. If you know what your doing you can push in the clutch, turn the engine off/on four times the CEL will go out. You can also reset it like you said and push the brake pedal a few times. I normally just pull the cable for 15 minutes. Hey it's a good time to clean the cables and use a good grease to seal them to keep moisture out. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RedDawg Posted December 19, 2013 Author Share Posted December 19, 2013 hmm so the code is still being thrown then as ive definitely turned the car on/off more than 4x since putting the hose back on. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 19, 2013 Share Posted December 19, 2013 So may be you have a bad front O2 sensor. Your best to get a OEM one to replace it. My aftermarket front only lasted about 2 years. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RedDawg Posted December 19, 2013 Author Share Posted December 19, 2013 is it terrible to drive with this code? I've got a 400mil roadtrip for the holidays on Saturday, I don't know if i'll have the time to climb under there and swap in a new O2 sensor. Link to comment Share on other sites More sharing options...
KRM Posted December 19, 2013 Share Posted December 19, 2013 changing it is as easy. remove the front pass side wheel, disconnect power to car of course, remove old part, then install new one. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 19, 2013 Share Posted December 19, 2013 I use a O2 sensor socket and wrap a screw type hose clamp around it to help hold it shape while trying to remove it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
IRNChip Posted February 7, 2014 Share Posted February 7, 2014 I had that code and replacing the o2 sensor seems to have fixed it. Link to comment Share on other sites More sharing options...
JmP6889928 Posted February 7, 2014 Share Posted February 7, 2014 Yup yup....Front O2 for sure. Link to comment Share on other sites More sharing options...
