RiceKiller2.5GTL Posted August 22, 2005 Share Posted August 22, 2005 I just purchased a new '05 Legacy 2.5GTL and I want to replace the stock exhaust (way too quiet) but I have come to the conclusion that I DO NOT want to VOID the warranty. I spoke to a parts manager at my local Subaru dealer and he said that Suabru does not make an exhaust for our cars as of now. Does anyone have any info on an exhaust for new Legacy GTs that is made by Subaru (SPT) that either is or is coming out shortly?? Thanks! Link to comment Share on other sites More sharing options...
redfly17 Posted August 22, 2005 Share Posted August 22, 2005 How will you void any type of warranty by modifying the exhaust? Link to comment Share on other sites More sharing options...
RiceKiller2.5GTL Posted August 22, 2005 Author Share Posted August 22, 2005 every person at the dealer I went to said that if i modify the car in any way i will void my warranty. Link to comment Share on other sites More sharing options...
deimos Posted August 22, 2005 Share Posted August 22, 2005 a cat back exhaust should be fine by your dealer unless the cat back breaks in which case subaru wont cover it. If you get into more than catback exhaust, ie: upipe, downpipe, etc, subaru will deny coverage on any problem that can be associated with the mod. If your A/c breaks they still have to fix it. Link to comment Share on other sites More sharing options...
melayout Posted August 22, 2005 Share Posted August 22, 2005 For more growl with the least impact on your warranty, do an axle-back, which is basically replacing the mufflers. They are a direct bolt-on and unless you install them incorrectly or they're not designed correctly, there are not going to break anything. The Lachute mufflers are pretty good. Sound clip galore here http://www.pimpmyauto.com/media_lachute.htm I keed I keeed Link to comment Share on other sites More sharing options...
Gire Posted August 22, 2005 Share Posted August 22, 2005 Its so loosely interpreted though... Most dealers will void anything that could be attributed to mods. "Radio not working? Sorry sir, it's because of the aftermarket springs you put in your car. Warranty denied." Just be prepared to have your powertrain warranty voided completely once you start modifying your engine and/or exhaust. Link to comment Share on other sites More sharing options...
wayne53 Posted August 22, 2005 Share Posted August 22, 2005 you make by far more threads than any member on this board. sorry, just an observation. Link to comment Share on other sites More sharing options...
redfly17 Posted August 22, 2005 Share Posted August 22, 2005 id like to see them argue how a cat back exhaust caused the radio/AC unit to break Link to comment Share on other sites More sharing options...
Xenonk Posted August 22, 2005 Share Posted August 22, 2005 you can get a set of STi Genome exhuasts or STi Twin Tip Mufflers from Subaru of Japan.. both are axle-backs.. see here: http://sapporo.cool.ne.jp/legacy-bp5/GENOME.jpg http://www.sclabo.com/partslist/images/parts/subaru-002_l.jpg http://www.rallispec.com/images_product/RST4407_small.jpg More Subaru "supported" exhausts here: http://www.rallispec.com/sub_engineinex.htm http://www.sclabo.com/cgi-bin/newparts/list.pl?num=1&car=1&maincat=7&subcat=701 http://www.sclabo.com/partslist/legacy.html Keefe Keefe Link to comment Share on other sites More sharing options...
Xenonk Posted August 22, 2005 Share Posted August 22, 2005 you make by far more threads than any member on this board. sorry, just an observation. He's cutting and pasting while just changing a few words to fit the title... A simple search could have fixed this issue.. or better yet, just PM a knowledgeable person on the boards here would do nicely. Keefe Keefe Link to comment Share on other sites More sharing options...
