tsmpwns Posted November 29, 2013 Share Posted November 29, 2013 Hey guys, i've been looking around the internet and i've heard that engine ticking noises are common with Subarus but none of the videos I've watched have sounded like the noise my car has been making since yesterday. I recorded two videos, one just after starting the car, and a second after i warmed it up. Any help or suggestions as to what it is or if this sound is normal would be appreciated. engine cold engine warm Link to comment Share on other sites More sharing options...
c-lo Posted November 29, 2013 Share Posted November 29, 2013 doesn't sound good to me. I'd have it flat bedded to the nearest shop. wouldn't drive it. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
Max Capacity Posted November 29, 2013 Share Posted November 29, 2013 Agree, have it flat bedded to a local repair shop. That doesn't sound good. I'm guessing it's something in the valve train on the drivers side. Good Luck 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
levicarroll Posted August 12, 2014 Share Posted August 12, 2014 He didn't post the results of his research on here, but if you look at Video number 2 in the comments on youtube, he states that the issue was a piece of metal hitting his flywheel, he bent it back and corrected the issue. Link to comment Share on other sites More sharing options...
MrTris Posted August 12, 2014 Share Posted August 12, 2014 He didn't post the results of his research on here, but if you look at Video number 2 in the comments on youtube, he states that the issue was a piece of metal hitting his flywheel, he bent it back and corrected the issue. That piece of metal being the guard under the engine -- little brass piece that covers the bottom of the engine? Link to comment Share on other sites More sharing options...
