jcole05 Posted November 27, 2013 Share Posted November 27, 2013 Hi guys. Have an '05 LGT, MT, running E85 and a BNR16g with all basic supporting mods. I have a clutchmasters CX300 which is failing after ~22K miles or so. Maybe a combination of reasons but I think that part is simply the power level of the car relative to the capacity of that clutch (based upon opinion of a reputable shop in my area and a reputable person on lgt.com). I've really liked the feel of this clutch as a replacement for stock as this car is 100% my DD. Can anyone give their opinion based upon their setup or experienced with other cars they've driven about the best possible way for me to go when I replace the fx300? Thanks. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted November 27, 2013 Moderators Share Posted November 27, 2013 I have a lightly used FX350 that will be up for sale shortly (December 7th) A few folks have been liking the spec stage 2 clutches, and I've also heard some good things about southbend clutches. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Max Capacity Posted November 28, 2013 Share Posted November 28, 2013 Do you know why this clutch only lasted a short time and do you plan to fix that ? Before I installed my Spec 2 clutch, I wiped the new flywheel and pressure plate surface with acetone to remove any oil that may have been there. The Spec 2+ I had in there before I put the new shortblock in had 85,0000 + miles and was still going strong. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jcole05 Posted November 28, 2013 Author Share Posted November 28, 2013 Well, from speaking to others I've assumed that the main factor shortening life is simply a mismatch between power output of the car and holding capacity of the clutch. One reason I posted here, though, was to see if others who had the same CM clutch had been able to put through upper 300s in terms of wtq (~370-390 depending upon conditions - this is airboy / virtual dyno mind you so take with whatever grain of salt necessary) and mid 300s (~340 - 350) whp without issue. If so, then maybe, as you are implying, there are other factors which led to shortening of the clutch life. Link to comment Share on other sites More sharing options...
