Up Pipe Cat causing knock
way2tall89
Hey all. Quick question. Have any of you heard about the stock UP on the LGT's causing knock because of the cat? I took my car into the shop and they did a diagnostic run with my car. They ran some logs and saw a couple things. 1) The cat in the up pipe appears to be getting very hot and not getting cool enough on freeway runs. They suspect this is what's causing the knock in my car. 2) The O2 sensor is reporting abnormally and he is wondering why it hasn't actually thrown a CEL with the numbers its pulling. He suspects due to the sustained heat of the cat on the UP that it might have burnt out the O2 sensor and that's where I'm getting bad fuel trims in my LV.
I initially took my car in to be looked at for an apparent oil leak I could physically see burning from the DP or turbo. I could smell it in the cabin. After a thorough inspection he concluded that this was a normal occurrence of oil vapor in the inlet seaping and suggested an AOS eventually. He wasn't too concerned. He did mention that octane can get lowered (we only have 91 where I live) and that too much oil in the shaft can cause an imbalance which can decrease the life of the turbo. Though he said the turbo looks amazing for 105k miles.
He said the main thing is getting that UP out and replacing the O2 sensor. He said his tuner (who logged the car) said the logs looked great other than these minor things. No major issues to worry about.Then we started talking about stage 2 stuff but I'm not quite ready to make that jump. If need be I can do the work myself when it comes to installing the UP and O2 sensor. I just wanted some opinions on if this information seems logical and sound to the LGT community. I believe this guy makes a very strong case but I don't know enough about engine knock to know if it can be validated. Any takers?
  • Mega Users
There's an egt sensor in the up pipe. Any idea what temps it was showing? I'm pretty sure if it was as bad as stated, it would throw a cel.
Replace the up with a catless one and see what happens. That should be replaced anyway. Look for a used sti up.
As for the oil dripping on the exhaust, the shop is full of shit and you should find another one. You have an oil leak. You probably also have a vac leak causing your bad fuel trims and knock.
Well if it is a true leak, its very very tiny. After almost 3k miles I'm down a 1/2 quart. This is after about a 1k mile non stop trip. I have 106k miles on the car. The invoice I received stated "There was the usual oil from the PCV system in the intercooler and the throttle
body". They said they didn't see any apparent signs of leaking around the turbo....
