DenCon509 Posted October 8, 2013 Share Posted October 8, 2013 Don't ask how it got there, but I must retrieve a house key that got stuck inside the horn cover on the steering wheel. I have searched, but found no how-to horn cover removal - plenty of how to remove the wheel (after the cover is off). The car cannot be driven until the metal key is removed. Does it just pop straight off? Help greatly appreciated. Link to comment Share on other sites More sharing options...
Zues Marine Posted October 8, 2013 Share Posted October 8, 2013 the airbag cover? Link to comment Share on other sites More sharing options...
DenCon509 Posted October 8, 2013 Author Share Posted October 8, 2013 Sure Link to comment Share on other sites More sharing options...
86bratman Posted October 8, 2013 Share Posted October 8, 2013 There are two torx bit screws, one on either side of the steering wheel. Can't remember the size off hand. You'll be removing the airbag assembly so disconnect the battery before just to be safe. Take those screws loose, pull the assembly out, remove key, reinstall. Link to comment Share on other sites More sharing options...
johnegg Posted October 9, 2013 Share Posted October 9, 2013 what he said. Link to comment Share on other sites More sharing options...
monkeyposeur Posted October 10, 2013 Share Posted October 10, 2013 Don't ask how it got there. So how did it get there? Link to comment Share on other sites More sharing options...
Zues Marine Posted October 10, 2013 Share Posted October 10, 2013 ....how did that get there? Link to comment Share on other sites More sharing options...
monkeyposeur Posted October 10, 2013 Share Posted October 10, 2013 He fell on it in the shower? Link to comment Share on other sites More sharing options...
DenCon509 Posted October 11, 2013 Author Share Posted October 11, 2013 Those two Torx screws are tight, but loosening them (they're captive screws) allowed me to remove the airbag and get to the key. It was jammed between the hub/spoke framework and the plastic back. He was holding the loose key in his hand, it fell right into the gap between the airbag and the wheel. Link to comment Share on other sites More sharing options...
86bratman Posted October 11, 2013 Share Posted October 11, 2013 I checked, its a T-27 torx, helps to have one of the torx screw drivers, those things are tight. Link to comment Share on other sites More sharing options...
