jbangoy Posted September 28, 2013 Share Posted September 28, 2013 http://static.opposedforces.com/epc_img/366495144005.png I need the gasket labelled 23 that goes between a shorty DP and the factory mid pipe. Is it the same as the up pipe gasket labelled 22 or a different size? The list on the site goes from 22 to 25. http://opposedforces.com/parts/legacy/us_b13/type_8/exhaust_system/exhaust/illustration_1/ Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted September 28, 2013 Moderators Share Posted September 28, 2013 2.5" 2-bolt gasket most likely. Check with any auto parts store. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Max Capacity Posted September 28, 2013 Share Posted September 28, 2013 2.5" 2-bolt gasket most likely. Check with any auto parts store. What he said, take the out one with one, they can match it up. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
krot84 Posted September 28, 2013 Share Posted September 28, 2013 This should be the part you're looking for #44011AG000 and it's not the same as num 22 - #44022AA170 Link to comment Share on other sites More sharing options...
