0Subie9 Posted September 13, 2013 Share Posted September 13, 2013 I have this low tone type of clunking noise. Almost like something is bouncing around in my trunk (trunk is empty btw) and i'm not sure where its coming from. I'm not sure if its the struts/shocks in the rear im hearing. Its a 09 2.5i with 66km on it btw. Didn't think the struts would go bad this soon if this is the case. I do hear the noise on smaller bumps in the road. Any ideas? How would I check to see if the struts are shot? Thanks, Chris Link to comment Share on other sites More sharing options...
RWebb Posted September 13, 2013 Share Posted September 13, 2013 Check the spare tire/ jack etc? Link to comment Share on other sites More sharing options...
gear_monkey Posted September 14, 2013 Share Posted September 14, 2013 I had same exact issue...clunk sound over speed bumps and such. It is most likely your rear upper bushings. Mine were toast and made that annoying clunk Link to comment Share on other sites More sharing options...
0Subie9 Posted September 14, 2013 Author Share Posted September 14, 2013 Its not very loud at all. Its such a low noise and its more like a low pitched rattle when I hit little bumps. I will check the spare tire and stuff today amd see if that helps. How do you check the rear upper bushings. Are you talking about the ones that are are the rear swing arm? Tapp'n Link to comment Share on other sites More sharing options...
gear_monkey Posted September 14, 2013 Share Posted September 14, 2013 You'll have to put car on a lift and get the weight off wheels. My mechanic then used a pry bar to check for play and we could also see the torn bushing s Mine were the upper control link bushings. Link to comment Share on other sites More sharing options...
apexi Posted September 14, 2013 Share Posted September 14, 2013 I would try to get a video or sound clip if you can, not sure if the sound is loud enough for that though. Link to comment Share on other sites More sharing options...
NewLegGT67 Posted September 15, 2013 Share Posted September 15, 2013 I think I have this issue as well. It started around 50Kish. I'm probably the only person that has Wu-Tang Clan and Paul McCartney on their mp3. Link to comment Share on other sites More sharing options...
0Subie9 Posted September 15, 2013 Author Share Posted September 15, 2013 Its definitely not loud enough to catch on camera. Its just very annoying and sounds like something in the rear suspension is loose. Its going in to get the drivers seat replaced so we will see if they can figure it out while it's there. Tapp'n Link to comment Share on other sites More sharing options...
Max Capacity Posted September 15, 2013 Share Posted September 15, 2013 Sway bar end links are bad. ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JJr Posted September 15, 2013 Share Posted September 15, 2013 I replaced my RSB, end links & brackets and I didn't re-tighten the end links after driving a few hundred miles. They were loose, after tightening, my clunking was gone. Or what Max says relpace them. Link to comment Share on other sites More sharing options...
0Subie9 Posted September 16, 2013 Author Share Posted September 16, 2013 Okay then that brings me to my next question. Should I get aftermarkets or through Subaru? Link to comment Share on other sites More sharing options...
