2010+ CS lip on 2010 LGT
valkrie hunter
Just wanted to start a documentation on a project that should have been a very bad idea..
So with the limited lip options for 5th Gen Legacies, I wanted to try something different. Bought a WRX CS style 1 replica lip and started seeing how much work it would take to get it to fit.
Let me know what you think!
http://i11.photobucket.com/albums/a155/ValkrieHunter/Pearl/IMAG1332-1.jpg
Lip getting mocked up and glued
http://i11.photobucket.com/albums/a155/ValkrieHunter/Pearl/IMAG1336-1.jpg
So after fabbing up the lip, I felt I needed to strengthen the brackets between some of the pieces (where the silver is seen on the pictures above). I used acrylic sheets to hold everything in place. Then filled each of the pieces with plastic epoxy from JB Weld and sand everything smooth. I need to finish fabbing up the brackets from when I initially cut the lip to fit the contour of the bumper
http://i11.photobucket.com/albums/a155/ValkrieHunter/Pearl/IMAG1343.jpg
http://i11.photobucket.com/albums/a155/ValkrieHunter/Pearl/IMAG1346.jpg
http://i11.photobucket.com/albums/a155/ValkrieHunter/Pearl/IMAG1347.jpg
  • 2 months later...
