06lgtspecb Posted August 20, 2013 Share Posted August 20, 2013 I recently purchased a 06 lgt with 52k. After doing some reading I noticed a post that mentioned if your cooling fan comes on while the car is cold during initial start up, it needs the relay/ecm recall done. I've noticed my cars fan will come on for a few seconds on start up then turn off but it doesn't do it every day/time. Well the dealer claimed to have replaced my relay years ago so I'm not sure what the issue is here. Im not sure if this even fits the criteria of the recall since the recall states the fan stays on continuously. Since the car is so new to me I'm not sure if this is even something to worry about, that's why I came to ask here. Is this related to the recall? Does this particular relay go bad every few years? Any help would be appreciated! Thanks Link to comment Share on other sites More sharing options...
thisisthenewsic Posted August 21, 2013 Share Posted August 21, 2013 is your a/c on when you start the car those certain times??? that will cause them to turn on when the car is cold if the relay fails and it fries that portion of the ecu the fans stay on 24/7. no matter if the car is hot or cold. Link to comment Share on other sites More sharing options...
bluesuby Posted August 21, 2013 Share Posted August 21, 2013 Give the dealer your vin and ask about the recall. My 2005 was done within months of purchase (new) and as is stated above the ECU needed replacement as well. Bring ALL your keys to the dealership because a new ECU means the keys must be reflashed. Link to comment Share on other sites More sharing options...
06lgtspecb Posted August 21, 2013 Author Share Posted August 21, 2013 I'm pretty certain the A/C wasn't on since I haven't had to use it much and I'm pretty good about turning it off prior to turning the car off. I'm not positive though so I will definitely pay closer attention. Blue, I have contacted the dealer and they said the recall had been done to the vehicle years ago. Link to comment Share on other sites More sharing options...
Danteneon Posted August 22, 2013 Share Posted August 22, 2013 Keep in mind that if you have the front defroster on, the A/C will cycle on with it making the fan come on. I like to cook my pets and my family. Use commas. Don't be a psycho. Link to comment Share on other sites More sharing options...
