reborngarcia1985 Posted August 12, 2013 Share Posted August 12, 2013 Is it a bad idea to used different clutch parts from different brands? Like the pressure plate from act and use a oem clutch disk and a throw out bearing from spec. Now those are just ie and that is not what I am thinking of using. Just wanted to see and hear what everyones idea was on this Link to comment Share on other sites More sharing options...
Max Capacity Posted August 12, 2013 Share Posted August 12, 2013 Clutch disc and pressure IMO must be a matched set. So yes, it's a bad idea. TOB can be from anyone. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
robinlsb Posted August 12, 2013 Share Posted August 12, 2013 What he said! "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
Max Capacity Posted August 12, 2013 Share Posted August 12, 2013 In fact they are only a few places that make TOB's. Back in 1979 I was at McCloud Clutches in So. CA. I was watching the guy open the BCA bearing box take out the TOB and put it in a McCloud box. I have the new Spec TOB that came with my Spec clutch but I use the TSK3 TOB, that I replaced when I did the new clutch. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
reborngarcia1985 Posted August 12, 2013 Author Share Posted August 12, 2013 So oem sti plate and flywheel using a act disk and tob are a no go then dam it ok . Link to comment Share on other sites More sharing options...
EJ25subie05 Posted August 13, 2013 Share Posted August 13, 2013 yeah dont mix them, i learned that the hard way from someones stupid mistake!!! Link to comment Share on other sites More sharing options...
reborngarcia1985 Posted August 14, 2013 Author Share Posted August 14, 2013 Ok there going that idea. Link to comment Share on other sites More sharing options...
