compression Posted July 30, 2013 Share Posted July 30, 2013 All stock 2005 Legacy 2.5i Let my car sit in the garage for 3 days. This morning fired it up. Right after cranking it fired up (like normal) but the idle was rough, and there was blue smoke out the tailpipe (burning oil). Also a rattle from the engine. Sounded kind of like it was from the valvetrain on driver side, but really hard to judge. After about 3-5 seconds the idle smoothed out and the smoke stopped and the rattle died down and everything was normal. Drove to work and it was perfect.... Never seen this before. It is my daily driver. Lets play the "guess whats wrong" game! I am open ears. I thought getting rid of my WRX would get rid of blue smoke/oil consumption for good? guess not... Link to comment Share on other sites More sharing options...
cseagle08 Posted July 30, 2013 Share Posted July 30, 2013 stuck lifter? Link to comment Share on other sites More sharing options...
compression Posted July 30, 2013 Author Share Posted July 30, 2013 Maybe oil bled out of the lifter after sitting so long, then it was all pissed off when running until oil got back into it. I just noticed I have some oil in my spark plug tubes as well, better change the valv cover gaskets... Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 31, 2013 Share Posted July 31, 2013 The lifter isn' the issue if anything it would be a bad valve stem seal allowing oil to seep into the chamber on the exhaust stroke. I think given the age of the engine sometimes sitting is the worse thing for it. When you get a chance take the cat-pipe loose from the manifold and see if there is any residue in the flange. If there is gunk then you might have one of a few problems: too rich condition caused by a bad AFR excess fuel being dumped down the manifold OR a bad valve stem seal or a bad PCV valve Link to comment Share on other sites More sharing options...
compression Posted August 2, 2013 Author Share Posted August 2, 2013 ughhhhh..... Link to comment Share on other sites More sharing options...
ResidentRedneck Posted August 27, 2013 Share Posted August 27, 2013 when i was not caring about my car, i let it get to about 10k miles before i changed my oil. everytime i started it, it did the same thing. changed the oil, used 15w40, went away. Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted August 28, 2013 Share Posted August 28, 2013 when i was not caring about my car, i let it get to about 10k miles before i changed my oil. everytime i started it, it did the same thing. changed the oil, used 15w40, went away. Choke this up as one more reason why I don't like to buy used cars. Link to comment Share on other sites More sharing options...
ResidentRedneck Posted August 28, 2013 Share Posted August 28, 2013 Choke this up as one more reason why I don't like to buy used cars. Well ya dont have to worry about buying it, cause I'm not selling it. Also, I have a 255 short block waiting to go in when this one's done. Sent from my SGH-M919 using Tapatalk 4 Link to comment Share on other sites More sharing options...
compression Posted August 29, 2013 Author Share Posted August 29, 2013 I found a little oil in the spark plug wells, so I replaced plugs, wires and valve cover gaskets (80k on plugs and they were quite worn out). I have let the car sit for 4-5 days without driving many times and the problem has not come back after that one time. So I think it was just a momentary anomally. Depreciation and car loans: Chalk this up to two more reasons why I dont like to buy new cars. Link to comment Share on other sites More sharing options...
