tDoug60 Posted July 25, 2013 Share Posted July 25, 2013 so the other day i installed a Perrin turbo inlet and right after the install when i engaged the clutch a owl like noise started, i just though it could be beacuse i had the car sitting for 5 days prior to the install. today when i was driving to work the owl like noise started when i was engaging the gas. i also have a small tear on my crank case breather hose if any one can help please chime in. o Link to comment Share on other sites More sharing options...
tDoug60 Posted July 25, 2013 Author Share Posted July 25, 2013 -_____- Link to comment Share on other sites More sharing options...
tDoug60 Posted July 26, 2013 Author Share Posted July 26, 2013 Any kind of help would be nice Link to comment Share on other sites More sharing options...
Shello007 Posted July 26, 2013 Share Posted July 26, 2013 Whoo!? Sorry, could it be your intake is sucking a lil more air and thus have a bit more of a sucking sound? Or, was everything secured and no leaks? Link to comment Share on other sites More sharing options...
tDoug60 Posted July 26, 2013 Author Share Posted July 26, 2013 Yes like a whoo. I believe everything was tighten down ill check after wok for leaks. But why would it be doing it while I engaged the clutch Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 26, 2013 Moderators Share Posted July 26, 2013 By "engage" the clutch do you mean depress it? If you are getting a noise that is related to travel in your clutch pedal it's most likely the TOB. Also, the likelihood of an inlet install being related to your clutch pedal in any way whatsoever is probably zero. I'm guessing TOB or inlet leak from new install. Have you boost leak tested the car since the install? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Code Posted July 26, 2013 Share Posted July 26, 2013 "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
tDoug60 Posted July 26, 2013 Author Share Posted July 26, 2013 Yes I mean when the clutch is depress. While I was on my lunch break. I was revving the gas and the sound appears than as well so I'm assuming its a leak somewhere. Link to comment Share on other sites More sharing options...
Shello007 Posted July 26, 2013 Share Posted July 26, 2013 Yes I mean when the clutch is depress. While I was on my lunch break. I was revving the gas and the sound appears than as well so I'm assuming its a leak somewhere. , Yep, so maybe when you depress the clutch and engine is no longer engaged, the sound is more audible. Link to comment Share on other sites More sharing options...
tDoug60 Posted July 27, 2013 Author Share Posted July 27, 2013 Anyone have a DIY for crank case breather hose. Link to comment Share on other sites More sharing options...
tDoug60 Posted July 28, 2013 Author Share Posted July 28, 2013 Anyone pls, Link to comment Share on other sites More sharing options...
