03silvertiger Posted July 12, 2013 Share Posted July 12, 2013 Just flushed my trans with macco systhetic fluid plus six and gas mileage dropped so i m chaning the fluid again but what is best for mpg royal purple? its an auto 2003 legacay Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 13, 2013 Share Posted July 13, 2013 Just flushed my trans with macco systhetic fluid plus six and gas mileage dropped so i m chaning the fluid again but what is best for mpg royal purple? its an auto 2003 legacay First off get whatever you put in there out and replace that with Subaru ATF. Secondly refer to the first Link to comment Share on other sites More sharing options...
N.sane Posted July 13, 2013 Share Posted July 13, 2013 +1. Nothing but Subaru OEM for my transmission. Link to comment Share on other sites More sharing options...
03silvertiger Posted July 13, 2013 Author Share Posted July 13, 2013 royal purple wouldnt be better? Link to comment Share on other sites More sharing options...
03silvertiger Posted July 13, 2013 Author Share Posted July 13, 2013 what about amsoil ATLQT-EA or the universal amsiol atf? Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 14, 2013 Share Posted July 14, 2013 what about amsoil ATLQT-EA or the universal amsiol atf? First off get whatever you put in there out and replace that with Subaru ATF. Secondly refer to the first Link to comment Share on other sites More sharing options...
apexi Posted July 14, 2013 Share Posted July 14, 2013 When I look up the owners manual for a 2003 subaru legacy L, it recommends a Dexron III automatic transmission fluid. Amsoil says the following about the fuel efficient synthetic atf: "AMSOIL Signature Series Fuel-Efficient Synthetic ATF is backward compatible and replaces DEXRON III fluids in older GM automatic transmissions. (DEXRON VI specification supersedes the obsolete DEXRON III in GM vehicles.)" AMSOIL Signature Series Multi-Vehicle Synthetic ATF also claims to be Dexron III compatible, therefore it sounds like either fluid should work. Link to comment Share on other sites More sharing options...
N.sane Posted July 14, 2013 Share Posted July 14, 2013 We're not saying the aftermarket stuff isn't compatible. All I'm saying is that OEM Subaru ATF works great and you can rest assured it's the most reliable option. Link to comment Share on other sites More sharing options...
apexi Posted July 14, 2013 Share Posted July 14, 2013 You're right, I'm tired and missed the point of this thread and its replies. 03silvertiger, what is macco synthetic fluid? Do you mean aamco? When I try to do a search for macco I come up with nothing, and aamco seems to be a car care center. I'm curious to see the specs of the ATF you're currently using. The only thing that catches my eye about the amsoil fuel efficient synthetic atf is that it's fairly thin when cold and hot, which I guess could possibly translate to a few extra mpg's. Link to comment Share on other sites More sharing options...
03silvertiger Posted July 22, 2013 Author Share Posted July 22, 2013 ok so this is the stuff i have in my car now http://mocaoils.com/getattachment/1f165960-3d3b-4680-b325-1ce81b8e0158/Universal-Automatic-Transmission-Fluid I was looking to some of the specs on the fluid this has 6.84cst at 100 degree C where as amoil fuel efficeincy is 5.93 and vavoline max life is 6.11 and i think i migh just goi with that Link to comment Share on other sites More sharing options...
