tocinoman25 Posted October 17, 2013 Share Posted October 17, 2013 here is the invite link on the midwest section http://legacygt.com/forums/showthread.php/sunday-10-27-tilted-kilt-schaumburg-meat-215632.html Follow me on IG @chefodiycarguy and @chefo.soriano Link to comment Share on other sites More sharing options...
Serb Legacy GT Posted October 17, 2013 Author Share Posted October 17, 2013 here is the invite link on the midwest section http://legacygt.com/forums/showthread.php/sunday-10-27-tilted-kilt-schaumburg-meat-215632.html Thanks, I was going to post it there too and got called off to a job...then forgot when I got home Link to comment Share on other sites More sharing options...
JMLegacy Posted October 21, 2013 Share Posted October 21, 2013 I was just curious about how your logs would look on a virtual dyno plot. Assuming ur car weighs over 3300 and u over 160 and the road was flat: http://s23.postimg.org/turgy2md7/serb_GT.jpg It corresponds with your MAF g/s... Link to comment Share on other sites More sharing options...
boostsr20 Posted October 22, 2013 Share Posted October 22, 2013 What was the cost of the tune? Link to comment Share on other sites More sharing options...
AFBeefcake Posted October 22, 2013 Share Posted October 22, 2013 My wife's automatic 05 Lgt with a Bnr16g, turbo inlet, spt intake, full exhaust, fms tmic, ebc and drop in fuel pump put down 299.6 WHP. Link to comment Share on other sites More sharing options...
Serb Legacy GT Posted October 22, 2013 Author Share Posted October 22, 2013 What was the cost of the tune? Link is here to their pricing section along with all info...http://pandlmotorsports.com/services/dyno-services/dyno-tuning-services/ Quick summary, tune with Cobb AP was $500, open source is $550, and AEM Vipec/Motec is $700...that price includes a pre-dyno inspection and you need to put down a non-refundable deposit of $100 at the time you make your appointment (in case you blow off your dyno tune session). My wife's automatic 05 Lgt with a Bnr16g, turbo inlet, spt intake, full exhaust, fms tmic, ebc and drop in fuel pump put down 299.6 WHP. Very nice, especially for auto. Link to comment Share on other sites More sharing options...
Bob in Chicago Posted December 2, 2013 Share Posted December 2, 2013 10 days ago, I had P&L install & dyno these mods: BNR-16EVO, 740cc DW injectors & DW fuel pump, AVO airfilter & inlet hose, Perrin MAF hose, Perrin TMIC, Grimmspeed boost solenoid, Perrin ELHeaders, Grimmspeed uppipe, Invidia 3" catted downpipe; Perrin 3" mid & Y to stock mufflers. Since I have a 5EAT, I wanted a safe, daily-driver tune with quick spool-up and best gas mileage at 3K. Result: 288.2 WHP severly limited by the stock mufflers! (torque not available) I'm going back for a custom, P&L muffler set-up and a fresh dyno-tune by Junior. Link to comment Share on other sites More sharing options...
ragman Posted December 3, 2013 Share Posted December 3, 2013 Result: 288.2 WHP severly limited by the stock mufflers! That sounds odd. Most have stated that stock mufflers only hold back ~2hp/20tq. Since you will have pre-post dyno results, please your new numbers after replacing the stock mufflers. Link to comment Share on other sites More sharing options...
Bob in Chicago Posted December 3, 2013 Share Posted December 3, 2013 I thought so too, but P&L said my ELH & Down pipe were glowing red hot during the pulls. The sound out the mufflers is tinny and not very low; they probably have internal rust. The abrupt transition from a full 3" exhaust to the 2.25" muffler flanges could make lot of back pressure. After the dyno, my original front O2 sensor pooped out (probably fried) as a result of the red-hot pulls and 74,000 miles. When it was replaced, all was good! Link to comment Share on other sites More sharing options...
Serb Legacy GT Posted December 4, 2013 Author Share Posted December 4, 2013 Interesting...maybe with the ELH and dp, and 16g the exhaust has become restrictive. My understanding is if I added ELH to my current setup it could net another 20whp/20wtq. You may get a nice bump in hp and tq with an exhaust. Definitely look forward to your numbers after the retune. They're great about emailing you a dyno graph so post that bad boy here! Link to comment Share on other sites More sharing options...
joeleodee Posted December 6, 2013 Share Posted December 6, 2013 That sounds odd. Most have stated that stock mufflers only hold back ~2hp/20tq. Since you will have pre-post dyno results, please your new numbers after replacing the stock mufflers. It was always my understanding that the stock mufflers did not rob much power on any setup using the stock turbo. Once upgrading the turbo like he has with the 16g, I'd figure that a healthy set of free flowing cans will net him some better results. Link to comment Share on other sites More sharing options...
Bob in Chicago Posted July 23, 2014 Share Posted July 23, 2014 July 2014 Update: P&L fabbed up SS 3" mufflers and dyno tuned it. Before they did it, they discovered I had a leaky fuel pump hose/line caused when they installed my DW65 fuel pump. This probably caused the previous red-hot headers and stumble off of low RPMs. RESULT: 289 WHP and no stumble & no red-hot headers. Since I have a 5EAT, they didn't generate a torque chart, but HP graph is a steady, smooth climb. Driveability now is terrific with no hesitation. Therefore, I cannot say that stock mufflers are a major block to HP. Mods: BNR-16EVO, 740cc DW injectors & DW65 fuel pump, AVO airfilter & inlet hose, Perrin MAF hose, Perrin TMIC, Grimmspeed boost solenoid, Perrin ELHeaders, Grimmspeed uppipe, Invidia 3" catted downpipe; Perrin 3" mid & Y to custom 3" in/4" out straight-thru "Streetpower" mufflers Link to comment Share on other sites More sharing options...
ragman Posted July 23, 2014 Share Posted July 23, 2014 Thanks for the follow up! So, you netted 1 HP by replacing the stock mufflers with Stainless 3" mufflers. Yeap, this is another strong case to show stock mufflers are not a restriction (at least under the 300 hp mark). How does the new set up sound? Link to comment Share on other sites More sharing options...
Bob in Chicago Posted July 23, 2014 Share Posted July 23, 2014 Low rumble at idle, deep purr at 60mph. Then it goes to a deep, Ferrari-like roar at high rpms. A bit too loud for my tastes, but tolerable. Net 1 hp could be actually more due to temp diff from dyno to dyno run (Nov to July.) Link to comment Share on other sites More sharing options...
Serb Legacy GT Posted July 25, 2014 Author Share Posted July 25, 2014 Proof right there that the stock mufflers are not a restriction at the 300 whp mark. Although you did not gain anything in terms of hp/tq, it seems like the car sounds much better and more aggressive. Sometimes the feel/experience is worth the price Link to comment Share on other sites More sharing options...
Steve ko Posted July 27, 2014 Share Posted July 27, 2014 Its good to see some other lgt tunes from P&L . They did some service & tuned my lgt wagon. I had the car about four weeks (Im the second owner) and it just didn't run right, JR had suspected a broken ringland, so back it goes to the Subaru dealer " costly extended warranty thank you" they replaced the suspect piston (broken ringland). I have put about 700 miles since then and the car is running great so far on the orginal tune, I plan on taking it back so Jr could touch up the tune with four good cylinders. Link to comment Share on other sites More sharing options...
MDW25gt Posted September 3, 2014 Share Posted September 3, 2014 Got a picture of the broken land? Link to comment Share on other sites More sharing options...
