PhilT Posted November 18, 2005 Share Posted November 18, 2005 As many of us are now taking data readings from our cars with Tari DL or Ecu Explorer, this thread is the place to post them up for discussion and comparison. It would be very helpful if we detailed all the mods with the results, so to compare apples to apples. Here's a couple to get started, readings I took stock, compared to my latest set up with; Stg 2 AP, PDE UP & catless DP, Perrin pulley and K&N panel filter.Stock.pdfStage 2 with pulley.pdf Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
trabbic Posted November 18, 2005 Share Posted November 18, 2005 GREAT IDEA!! Here is my Stock V. Stage 1 (Cobb) with graphs included... Stage 1 1.15 93 Oct. (BP Gas). Stock graphs are actually without Intake Silencer. All pulls done in 3rd gear.Graphs.pdfStage1.pdfStock.pdf My vB Garage How to Install Steering Wheel Radio Controls Cubby Gauge Mounting Solutions Link to comment Share on other sites More sharing options...
trabbic Posted November 18, 2005 Share Posted November 18, 2005 Here are more logs They compare stock airbox, no resonator (intake silencer), and the zip tie mod, discussed here: http://legacygt.com/forums/showthread.php?t=22563 All runs were made at Cobb Stage One with Tari DL1, back to back within 2 or so hours...stock1.pdfstock2.pdfno res1.pdfno res2.pdfno res3.pdfZip1.pdfzip2.pdfZip3.pdf My vB Garage How to Install Steering Wheel Radio Controls Cubby Gauge Mounting Solutions Link to comment Share on other sites More sharing options...
PhilT Posted November 18, 2005 Author Share Posted November 18, 2005 This is one I took before any ECU mods, but just with a short ram intake. You can see how the exhaust temps are much higher than normal and the ECU is pulling timing by the negative KC. As you can imagine, I promptly removed it !Stock with intake.pdf Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
CHRISPY Posted November 18, 2005 Share Posted November 18, 2005 Take a look at the ziptie data compare it to the resonator removed data. The Ziptie mod shows a peak of 243.13 with with only 12.0#'s boost. The resonator mod shows a peak 242 grams/sec but at 12.7#s boost. I think with more learning and 12.7s# boost on the ziptie mod you'll see even more grams/sec showing up on the MAF flow. This shows that even with less boost from the turbo you are seeing identical MAF flow. If the boost from the turbo was up to 12.7 you'd see even more airflow from the ziptie mod. This weekend I'll try and meet up with Phil and we'll do some logging in my car. Cheers, Chris Link to comment Share on other sites More sharing options...
abakja1 Posted November 19, 2005 Share Posted November 19, 2005 Ok,..seems there are still conflicting comments on whether to take the resonator out or no (even with the resonator/air intake thread at Modification thread),...I dont think I will ziptie my KN as there really is too much dirt and warm/hot air to think about unless you do make some sort of cold air box or divider,..Not really worth the time/effort for petty hp numbers,..Id take out the resonator just for the cool sound, but only if throttle response/hp/tq are not negative or detrimental to performance and driveability,... My opinion is that, I originally took out my resonator and have a KN filter and noticed the louder intake noise and BOV sounds,..However, throttle response with a quick accelerator pedal jab or "punching it" was not too responsive though,..Dont know if it was the ECU (pre-AP flash) slow response due to throttle-by-wire,.. So,..I put back the resonator and the throttle response seemed better,..but this is butt dyno testing,...I think Pantagonian GT commented the same observations as I did,...For me, I dont mind trying it out as it really only take about 5-10 minutes to take resonator out,.. So I maybe wrong and,...If CHRISPY's datalogging is showing better numbers,..IS taking the resonator off a good thing (I think I may screw in an aluminum sheet to cover resonator hole too)??? Link to comment Share on other sites More sharing options...
CHRISPY Posted November 19, 2005 Share Posted November 19, 2005 the MAF flow is telling you how the airflow is into the motor. The stock setup is worse than both the ziptie and resonator. My wife didnt like how loud the ziptie mod was so I put in the cover but removed the resonator this morning If the MAF flow is higher (average and peak) you WILL make more power once the computer learns in the increased airflow and adjusts STRIMS/LTRIMS/pulsewidth etc. MAF flow is directly proportional to HP potential. Cheers, Chris Link to comment Share on other sites More sharing options...
Chief_Wiggum Posted November 19, 2005 Share Posted November 19, 2005 Can you guys please include the octane rating for the fuel you're using? Curious to see the timing info on different gas. Thanks! Link to comment Share on other sites More sharing options...
PhilT Posted November 20, 2005 Author Share Posted November 20, 2005 I tried the "poor man's" cold induction this evening, not with zip ties but with duct tape, eh ! The results are not conclusive, in fact there is hardly any difference at all. MAF is the same with or without, boost is the same, EGT's the same, the only major difference is that the intake temp is much higher without the snorkal at low speeds, as we expected, but cools off to the same levels once the car gets moving. Anyway, here are the results, see what you think.Stage 2 V1.15 93 oct.pdfStage 2 V1.15 93 oct wo filter box.pdf Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
CHRISPY Posted November 20, 2005 Share Posted November 20, 2005 Phil, Can you graph MAF flow and boost in excel for me and post the graph comparing both runs? Did you duct tape over the filter or around the edge of it? Link to comment Share on other sites More sharing options...
PhilT Posted November 20, 2005 Author Share Posted November 20, 2005 Chris, IM me your email address and I'll send you the file in excel, might take me a while to do the graphs. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
CHRISPY Posted November 20, 2005 Share Posted November 20, 2005 PM sent Link to comment Share on other sites More sharing options...
mwiener2 Posted November 20, 2005 Share Posted November 20, 2005 Do all of you have adobe acrobat or is acrobat smart enough to take an excel sheet and make it look like that just by changing the extension? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
PhilT Posted November 20, 2005 Author Share Posted November 20, 2005 I have acrobat yes, it converts any file to a *.pdf Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
mwiener2 Posted November 20, 2005 Share Posted November 20, 2005 i meant if i take an .xls file and change it to .pdf, will acrobat reader handle that? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
PhilT Posted November 20, 2005 Author Share Posted November 20, 2005 Nope, it has to be converted. Because we can't attach excel files to a post, what you can do though, is change the extension to .pdf, then whoever wants to view it has to save it first, then change the extension back to xls. and open it in excel. Like this attachment; it's really an excel file but I changed the extension to .pdf so I can attach it. If you want to view it, save it, then change the extension back to .xlsTest.pdf Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
CFar Posted November 21, 2005 Share Posted November 21, 2005 Phil T, what kind of intake did you have and what were the conditions leading to the higher EGTs? How high did the EGTs get? Link to comment Share on other sites More sharing options...
CFar Posted November 21, 2005 Share Posted November 21, 2005 Ok I see that you had a DIY intake on before. Is that the intake that you had on while you ran those numbers? Did you ever have any CEL's with it (if you had it on long enough) and was the piping surrounding the MAF the same as stock or bigger? If anyone with a K&N typhoon can log some numbers that would be great, or better yet, I invite anybody with data logging capability to meet me somewhere in NOVA so we can test an otherwise stock car and see how the k&n does. I need someone to do it soon as I dont know how long Ill be at this current state of tune. Chris Link to comment Share on other sites More sharing options...
mwiener2 Posted November 21, 2005 Share Posted November 21, 2005 here's two logs from right after my protune. Save them then change the file extension from .pdf to .csv2, 4th, Agile realtime, stg2 v110.pdf6, 4th pull, Agile realtime, stg2 v110.pdf My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
CFar Posted November 21, 2005 Share Posted November 21, 2005 I suppose its safe to say that the lowest reading the AFR guage will provide is ~11.1/1. You have it tuned to drop straight to its lowest possible value on full throttle. Safe but man you must use some gas. Chris Link to comment Share on other sites More sharing options...
mwiener2 Posted November 21, 2005 Share Posted November 21, 2005 well what do you expect? 30mpg at WOT making 300 ftlbs? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
CFar Posted November 21, 2005 Share Posted November 21, 2005 Maybe if you rode down hill everywhere you went. Thats a good end result in the end though. What were the power numbers? Link to comment Share on other sites More sharing options...
mwiener2 Posted November 21, 2005 Share Posted November 21, 2005 http://legacygt.com/forums/showthread.php?t=22212&highlight=protuned My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
PhilT Posted November 21, 2005 Author Share Posted November 21, 2005 Ok I see that you had a DIY intake on before. Is that the intake that you had on while you ran those numbers? Did you ever have any CEL's with it (if you had it on long enough) and was the piping surrounding the MAF the same as stock or bigger? If anyone with a K&N typhoon can log some numbers that would be great, or better yet, I invite anybody with data logging capability to meet me somewhere in NOVA so we can test an otherwise stock car and see how the k&n does. I need someone to do it soon as I dont know how long Ill be at this current state of tune. Chris I never hasd any CEL's, I think I read somewhere that the light comes on at 1,800 degrees. The pipe is exactly the same diameter as stock, with the 'H' air straighteners in it too. For some reason the MAF was sensing lower g/s of air and reducing the fuel. I think the airflow was there, just not being metered, and with the reduced fuel I got the lean mixture and high EGT's. I would love to see some logs from someone with a Perrin or a K&N, to see if they are any different than mine. No volunteers yet though. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
CFar Posted November 22, 2005 Share Posted November 22, 2005 Im trying to piece together a cord and laptop to get it done with no luck so far. The choice in cords is confusing to say the least but hopefully I can get it ironed out tomorrow. Link to comment Share on other sites More sharing options...
