SCHNITZ93 Posted June 27, 2013 Share Posted June 27, 2013 Hi I am looking to buy a used single mass flywheel I can resurface and install in my 05 LGT Link to comment Share on other sites More sharing options...
apexi Posted June 27, 2013 Share Posted June 27, 2013 Are you looking for new or used? OEM or aftermarket? Some of the popular vendors on here sell new OEM ones, as well as new aftermarket ones. Here are some links to the new OEM single mass flywheels. Fred beans parts out of Doylestown, PA sells them http://www.fredbeansparts.com/subaru-oem-single-mass-flywheel.html Infamous performance out of CA also sells them http://www.infamousperformance.net/servlet/the-325/Subaru-OEM-Single-Mass/Detail And I'm sure AZP in NJ could help you get one if you contacted them as well http://azpinstalls.com/ *my mistake, I overlooked "used" in your post. Link to comment Share on other sites More sharing options...
ssbtech Posted June 27, 2013 Share Posted June 27, 2013 Why do you want used, and what are you planning on doing with it? Stock engine? If staying stock, the OEM 2008+ Legacy clutch works fine in the 05. Or whatever year they moved to the SMFW. Maybe it was '07. Link to comment Share on other sites More sharing options...
SCHNITZ93 Posted June 27, 2013 Author Share Posted June 27, 2013 Thanks Ill check out those sites. I want used because it is cheaper and will work fine once resurfaced. Im starting to feel the clutch slip so Im putting a new clutch in and switching the DMF to a SMF while im in there. No not a stock engine I have a TD05 16G, 550cc injectors, bigger fuel pump, Perrin innercooler, Couple other things I forget. Link to comment Share on other sites More sharing options...
Xplosivo1 Posted June 28, 2013 Share Posted June 28, 2013 I don't know if you were aware, but this is the note on FB parts: "Note: 2005-2006 models must use a 2007-2009 Clutch Kit with this Flywheel. You cannot use your OEM 2005-2006 Clutch set-up along with this Flywheel." Wouldn't want you to have to take it all apart again... Link to comment Share on other sites More sharing options...
SCHNITZ93 Posted June 28, 2013 Author Share Posted June 28, 2013 I am aware of that but thanks for makin sure Link to comment Share on other sites More sharing options...
idiot4hire Posted June 29, 2013 Share Posted June 29, 2013 If you want a spec clutch ill sell you my spec flywheel extremly cheap Link to comment Share on other sites More sharing options...
Max Capacity Posted June 29, 2013 Share Posted June 29, 2013 EWIW, I enjoy my Spec Clutch. I have a Spec 2, it's a little firmer then stock but grabs a whole lot better. Very smooth from the very first time I pushed on it. You should buy his FW and order a Spec clutch from AZP. Also think about the TSK3 kit, grease the starter shift when it's out, grease the tranny snout where the TOB slide and the end of the input shift where it goes into the pilot bearing. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
