Gawnshanning Posted June 26, 2013 Share Posted June 26, 2013 I'm going to be changing my engine in a couple weeks (spun bearing) but I was wondering what I should be doing to help the engine last? I know I'm going to be changing all fluids, motor mounts, spark plugs and wires, and timing belt. If anyone has other thoughts to what I should also do, let me know P.s: I will add pictures of my operation Link to comment Share on other sites More sharing options...
Max Capacity Posted June 26, 2013 Share Posted June 26, 2013 http://legacygt.com/forums/showthread.php/got-some-new-stuff-engine-r-r-184106.html Start here. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Xplosivo1 Posted June 26, 2013 Share Posted June 26, 2013 Make sure to break it in properly, check and change the oil regularly...religiously. You may want to invest in some tohyo roki oil filters, but thats not a requirement. Use a high quality motor oil, Rotella T6 is recommended for the turbo application; I don't know if its necessary for the 2.5i. Are you having your engine rebuilt or buying a new block? How many miles are on the current engine? I'd recommend changing the water pump if your new engine doesn't come with one. Link to comment Share on other sites More sharing options...
Gawnshanning Posted June 27, 2013 Author Share Posted June 27, 2013 Make sure to break it in properly, check and change the oil regularly...religiously. You may want to invest in some tohyo roki oil filters, but thats not a requirement. Use a high quality motor oil, Rotella T6 is recommended for the turbo application; I don't know if its necessary for the 2.5i. Are you having your engine rebuilt or buying a new block? How many miles are on the current engine? I'd recommend changing the water pump if your new engine doesn't come with one. Yeah im going high quality everything from oil to filters. wont have a turbo so im not worried about that. I'm buying a rebuilt motor. My friend is a mechanic, I'm going to have him double check over everything, but from what I saw it looks good to go. Current engine has about 102000. Link to comment Share on other sites More sharing options...
