Va_lgt Posted June 26, 2013 Share Posted June 26, 2013 Ok so I'm in the middle of e-tuning and I was pulling a 2nd gear log just to make sure everything was good to do a 3rd gear one and everything felt fine but when I looked back at the log from romraider I saw that the Manifold relative pressure colum go to 20 peak and then tapered to 18.5 for a few cells the dropped from 8 to 5 to 4 to 2 then to 0 by like 4500rpm. Now what's strange to me is that the car still acts completely normal.ebcs? Isn't that what feeds the ecu with the Mrp value? And I'm not sure if its really related but there is a very strange spooling noise at the beginning of spool when you put alot of load on the motor( like 3rd gear at30-40mph and wot 4th at 40-50 mph and wot) it sounds almost like boost flutter and its metalic sounding, just strange. Ive got a video of the noise and ill post it up ASAP. Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
ras06LGT Posted June 26, 2013 Share Posted June 26, 2013 The flutter sound is most likely a bit of wastegate flutter as the boost quickly builds. Don't know where the pressure sensor is actually located. Link to comment Share on other sites More sharing options...
Va_lgt Posted June 28, 2013 Author Share Posted June 28, 2013 Ok, the 0 value was due to the "check valve"( that's what it looks like) in the vac line leading to the map sensor being cracked off. So I fixed that but still have the "flutter" noise Link to comment Share on other sites More sharing options...
cryo Posted June 29, 2013 Share Posted June 29, 2013 The noise is normally flutter at those rpms and speeds since the wg is doing everything possible to build boost. The easy solution is to downshift most times to put the engine/transmission in its efficiency range unless your doing it specifically for testing purposes. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
