Blumpkin Posted June 13, 2013 Share Posted June 13, 2013 So I removed my wing and would like some opinions on my next step. I have 3 options I am considering to fill the holes. 1. The bondo route 2. Fiberglass 3. Tac welding the holes closed and hammering/sanding it smooth All of thus prior to a repaint of the trunk, so what would y'all do? Link to comment Share on other sites More sharing options...
jav2.5 Posted June 13, 2013 Share Posted June 13, 2013 Isn't there a swap trunk lid thread, maybe you can find someone that wants to swap. Link to comment Share on other sites More sharing options...
Blumpkin Posted June 13, 2013 Author Share Posted June 13, 2013 Been trying for a year unfortunately Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted June 13, 2013 Share Posted June 13, 2013 #3 then, #1, prime sand, repeat until smooth, then paint. Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
JmP6889928 Posted June 15, 2013 Share Posted June 15, 2013 I would say Hammerdown is right BUT....rather than fill them in right away, make sure that you actually like it better without the wing. Go to Lowe's and buy some carriage bolts and nuts that fit the holes. Lowe's also has small rubber washers (these are all available in their hardware section) and then put a bolt and rubber washer and a nut inside of the lid and snug up to seal it out. Touch up paint the heads of the bolts so they're the right color and drive it for a couple of weeks to make sure that you're happy with how it looks, THEN do #3 if you are, and if you aren't, put the wing back on and no harm done. Link to comment Share on other sites More sharing options...
Blumpkin Posted June 16, 2013 Author Share Posted June 16, 2013 already did that JmP and I love the look, however, I am going to find someone who has a 2.5i or save up for a carbon fiber wingless trunk, the cf is only 100 bucks more brand new than a regular one. Link to comment Share on other sites More sharing options...
