mattcornelison Posted June 12, 2013 Share Posted June 12, 2013 I have a 2.5i with 106k i bought used i have no idea if tranny fluid has ever been replaced. I saw that it might be a bad idea to have it flushed or remove plug and change some of it after 100k if it has never been changed. Any recommendations? Also car shifts fine no tranny problems just trying to mantain car. Link to comment Share on other sites More sharing options...
rob-2 Posted June 12, 2013 Share Posted June 12, 2013 If you can pull the service records it's best to follow what's been done. If you have doubts, a simple drain and fill is best. If you fear it's never been done, do a drain/fill and repeat a few times every 5k for 2-4 times. The flush is a concern if it's never been done, as junk gets pushed around. Last one should have been done around 90K. Link to comment Share on other sites More sharing options...
FJuan Posted June 13, 2013 Share Posted June 13, 2013 +1 ^^ If it was me, I would do a simple drain and fill, if you notice the fluid is darker, then I would repeat again after 5k miles. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
mattcornelison Posted June 13, 2013 Author Share Posted June 13, 2013 I just called the dealership they found the vin looks like they did the 90k but no flush just a dump and the rear diff. What all does the normal 90k service include she wouldn't tell all that way I can save some time with other maintenance Link to comment Share on other sites More sharing options...
ibr_adam09 Posted June 13, 2013 Share Posted June 13, 2013 timing belt. Link to comment Share on other sites More sharing options...
FJuan Posted June 13, 2013 Share Posted June 13, 2013 I would do a full tune up, just to be on the safe side. Timing belt Spark Plugs Acc belts Trans fluid My wife's balls are delicious. Link to comment Share on other sites More sharing options...
mattcornelison Posted June 13, 2013 Author Share Posted June 13, 2013 alright will do thanks Link to comment Share on other sites More sharing options...
jp233 Posted June 13, 2013 Share Posted June 13, 2013 dont forget coolant. but by 90k it should have been changed once already, minimum. Link to comment Share on other sites More sharing options...
