07spec_b Posted June 12, 2013 Share Posted June 12, 2013 I got a new shortblock installed. I logged the car after break in and it shows a constant -5 deg of knock after about 10% throttle even with the sensor off the block or unplugged. The tuner said its mechanical and didn't want anything to do with it. I went to the builder and he couldn't figure it out, said he will make some calls. Now all I hear is crickets. With ignition on I have 3v sensor unplugged and 1.8v sensor in. Knock sensor has 540kohm resistance. New sensor shows the same. Any input would be much appreciated. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 12, 2013 Share Posted June 12, 2013 http://legacygt.com/forums/forumdisplay.php/tuning-alliance-121.html Ask him or post this in the Tuning forum. Good Luck 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
07spec_b Posted June 14, 2013 Author Share Posted June 14, 2013 I can once I figure how to move the thread but I was told its not an tune issue. Link to comment Share on other sites More sharing options...
07spec_b Posted June 14, 2013 Author Share Posted June 14, 2013 I unistalled and reinstalled the Cobb and it shows no knock. Hopefully that was it. Link to comment Share on other sites More sharing options...
07spec_b Posted June 18, 2013 Author Share Posted June 18, 2013 That wasn't it only worked the first time I fired up the car. Link to comment Share on other sites More sharing options...
