SCRAPPYDO Posted August 11, 2005 Share Posted August 11, 2005 I am getting my spoiler today in the mail as the UPS notification has it out for delivery. Pending the gorillas at UPS not destroying it like my last lip, how do you guys recommend painting it. Duplicolor? Any other brands. colors? I have a black legacy. I was going to get it painted at a professional shop, but do not think its worth it. Should it be primed? Is the stock hardware/tape strong enough. Just looking for the best results, as I have been waiting for a while to do this mod. Thanks! SCRAPPYDO Link to comment Share on other sites More sharing options...
MaStaMooN Posted August 11, 2005 Share Posted August 11, 2005 i would only let a pro-shop do it.. spraypainting something like that will hardly ever look like the factory prime/paint/clear... And if its fiberglass.. it will most likely need some work done to it anyway.. some filler and stuff like that. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
SCRAPPYDO Posted August 12, 2005 Author Share Posted August 12, 2005 WEll the product looks good from the vendor..but dont know about if primer is necessary or flex angent or adhesive promoter... its tough.. I am a wrench turner, not a painter.. Link to comment Share on other sites More sharing options...
TRS Posted August 13, 2005 Share Posted August 13, 2005 It depends on what kind of look you want. If you want to match the body color (metalic paint w/clearcoat) then you might want to have a shop do it. I wanted something that sort of went with the flat black insert in the rear valance. Considering the condition of the package that UPS dumped off at the front door (see below), it needed suprisingly little prep. I used some 220 grit sandpaper on the couple of imperfections, then some 400 followed by 600 grit. I don't know if it's necessary but I used this Adhesion Promoter, followed by multiple light coats of this Trim Paint. I don't remember the exact price, but I think each can was ~$6. Some (not great, sorry) pictures are here. Link to comment Share on other sites More sharing options...
FPerron Posted August 18, 2005 Share Posted August 18, 2005 I wanted to be able to easily remove my spoiler (they make bad snowplows in winter), so I used small bolts (and large washers) instead of the tape. There is plenty of room for them all along the middle section of the spoiler. Also, by supporting this section with bolts, you stabilize the spoiler and reduce the chance of breakage if you tap a curbing with the leading edge. Link to comment Share on other sites More sharing options...
dark_rex Posted August 18, 2005 Share Posted August 18, 2005 i would definitely reccomend using some flex agent on fiberglass. my WRX grill lasted about a year until it was pitted and spotted to death. i had it repainted with flex agent the second time, and a year later, it still looked new. dR Link to comment Share on other sites More sharing options...
scans007 Posted August 19, 2005 Share Posted August 19, 2005 Well I tried painting it, it came out OK........brought it to a shop for glossy black paint and clear coat finish......60 bucks...I think it was worth getting it done professionally. Link to comment Share on other sites More sharing options...
P06781 Posted August 19, 2005 Share Posted August 19, 2005 I used a spray can of plasticote black trim paint from a auto parts store. I sanded with 400 grit and wiped it down w/ acetone. The paint came out great and looks almost like carbon fiber. I already bottomed out once crossing a intersection into my parking lot at work. You will likely do this too so just use something you can fix up easy yourself. Jim Link to comment Share on other sites More sharing options...
