doteleven Posted August 11, 2005 Share Posted August 11, 2005 Hi, I'm probably going to trade in my R32 for a Legacy... I have a great set of lightweight summer wheels - Enkei RPF1s with Goodyear F1 tires in 18". Same bolt pattern, but 35mm offset. I understand stock scrub radius from the sticky thread to be 53mm. Will there be alot of poke? Or could I just get fenders rolled? Or should I just sell them and get a new set? Albert Link to comment Share on other sites More sharing options...
PGT Posted August 11, 2005 Share Posted August 11, 2005 width?? If you had 9 inch wide wheels, it might work. Link to comment Share on other sites More sharing options...
Xenonk Posted August 11, 2005 Share Posted August 11, 2005 Most likely not since most VWs use a lower offset, causing the wheels to stick out a bit. You can try to put them on a GT, but my thoughts are that you need to FENDER FLARE it, not just roll it. Keefe Keefe Link to comment Share on other sites More sharing options...
