05-LGT Posted June 10, 2013 Share Posted June 10, 2013 I was driving ~ 30 mph on slight downhill when my check engine light went on. I was low on fuel but the fuel light didn't turn on. The on-board computer estimated my remaining range at 60 miles. 10-15 secs later the engine shut off. I pulled over to the shoulder, stopped and tried to start the engine again. It turned over but wouldn't start. I towed to my mechanic friend's shop. He said the error code was a fuel pump problem. However, he checked the fuel pump and said it was working fine. He thinks it could be an ECU problem but he doesn't have a spare test ECU to swap out and test. He called Glendale Subaru (Los Angeles County) and there are only apparently 4 in the country, all on the East Coast. The ECU is around $180 but he's not confident it's the ECU so I could be spending 200 bucks when it may be a different problem. A possible next step is to tow to the dealer since they should have a test ECU but I'd obviously rather not do this unless it's the only solution since the moment I tow it there I forsee a $500 invoice coming not matter what I do... Thoughts/ ideas/ recommendations? Link to comment Share on other sites More sharing options...
wurkenman Posted June 10, 2013 Share Posted June 10, 2013 I had similar issues with mine. I "thought" it was the ECU. I purchased a used ECU and made my appointment at the dealer (ECU's are NOT plug and play). After the ECU replacement and pairing with the system, it turns out it was the BIU (body integrated unit). This controls ALL of the functions of the car except the engine, hence ECU. Good luck. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
05-LGT Posted June 21, 2013 Author Share Posted June 21, 2013 Ok. Thanks. So it sounds all ECU work needs to be done at the dealer? Is there anyway to assess the problem before committing to go there? I know I'm screwed once I'm there so I want to make sure it's the last option. Someone told me the ECU is tied to a car's VIN and only dealers can do this?? Link to comment Share on other sites More sharing options...
heiche Posted June 21, 2013 Share Posted June 21, 2013 what error code(s) do you have? wonder if the fuel pump is actually getting voltage and running? (it should prime for a couple of seconds when the key is turned from off to on) BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
05-LGT Posted July 9, 2013 Author Share Posted July 9, 2013 Code was P0230 which is supposed to be the fuel pump. The pump didn't prime but my friend the fuel pump works fine. Ideas? Link to comment Share on other sites More sharing options...
heiche Posted July 9, 2013 Share Posted July 9, 2013 post #15 in the thread below has a test procedure that might help. http://legacygt.com/forums/showthread.php/p0230-fuel-pump-primary-circuit-malfunction-after-tgv-deletesi-160879.html BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
fahr_side Posted July 9, 2013 Share Posted July 9, 2013 post #15 in the thread below has a test procedure that might help. http://legacygt.com/forums/showthread.php/p0230-fuel-pump-primary-circuit-malfunction-after-tgv-deletesi-160879.html This. Do not start pissing about swapping the ECU on the advice on your friend. It is not a trivial matter. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
