Moddiction Posted June 10, 2013 Share Posted June 10, 2013 The rear in my 08 legacy gt just started making these squeezing noises recently. Seems most common noises are from the sway bar bushings. Does this sound like that is the source of the noise? Or possibly shocks? Both sides bounce a bit after pushing down but this car has such soft suspension that might be normal. Car has 75k miles on it now. Stock suspension and all. http://i123.photobucket.com/albums/o281/ryangreene555/S2000%20pictures/682EF84A-011A-4B3F-94A7-8F04AF36CC46-46086-00001727336558FC_zps857dd61c.mp4 WWW.MODDICTION.COM Moddiction Stainless steel and Titanium shift knobs. Drivetrain, suspension, brakes, exhaust, cooling, fuel, gauges+MUCH more! Link to comment Share on other sites More sharing options...
GEE-OTTO Posted June 11, 2013 Share Posted June 11, 2013 Not the shocks as they would make a dense creaking sound most noticeable when going over speed humps or rapid angle changes (entering a road from a steep driveway etc) from inside the car. It may also sound like a binding and clicking if that makes sense. Sounds like you need to grease the RSB bushing first and that is the easiest attempt at solving the issue. Also the squeak appears equally as loud and initiated from either side, the RSB is the common link btwn the two. Do a visual inspection of RSB mounts/bushing and links have someone bounce the car and see if you can identify the noise. Link to comment Share on other sites More sharing options...
13fido13 Posted June 11, 2013 Share Posted June 11, 2013 I have installed grease fittings in the RSB bushings to be able to grease them. This prevents the noise for a few months. Do it every service and you should be fine. Link to comment Share on other sites More sharing options...
