Bicyclemech1 Posted June 7, 2013 Share Posted June 7, 2013 Currently running stock springs with fresh stock struts and front 20mm stock bar/rear outback 18mm bar. Bars are fitted with new prothane bushings and fresh stock end links. Suspension is taught, with no clunks or rattles, and the ride quality is quite nice. It does sit a bit high. A 1.5" drop would certainly look better. Can anyone give me a source for lowering springs that will stay close to the stock wagon spring rates? First post for me!! Link to comment Share on other sites More sharing options...
blankdeluxe Posted June 7, 2013 Share Posted June 7, 2013 Currently running stock springs with fresh stock struts and front 20mm stock bar/rear outback 18mm bar. Bars are fitted with new prothane bushings and fresh stock end links. Suspension is taught, with no clunks or rattles, and the ride quality is quite nice. It does sit a bit high. A 1.5" drop would certainly look better. Can anyone give me a source for lowering springs that will stay close to the stock wagon spring rates? First post for me!! wrx wagon springs. 02-07 I believe. Link to comment Share on other sites More sharing options...
pleaidestar Posted June 7, 2013 Share Posted June 7, 2013 The wrx wagon springs will lower you a little but maybe only 3/4-1". Spring rates are great and with the new prothane and new struts you will be tracking pretty good. Link to comment Share on other sites More sharing options...
Zues Marine Posted June 7, 2013 Share Posted June 7, 2013 1.5" is more of a drop than people think, id say the OEM wrx springs go down mayyybe .5" Link to comment Share on other sites More sharing options...
pleaidestar Posted June 7, 2013 Share Posted June 7, 2013 1.5" is more of a drop than people think, id say the OEM wrx springs go down mayyybe .5" ^ that it is, I thought I wanted that much of a drop until a guy I know here put h+r's on his 98 ls it brought his 17's pretty close to the wheel opening. He has 5mm spacers in there too though. I like adjustability. Link to comment Share on other sites More sharing options...
Zues Marine Posted June 7, 2013 Share Posted June 7, 2013 yeah i had those h&rs on gr-2s and after it settled it was like -1.75"F, -2"R with 17s and 225/40... had to roll the fenders... likely wheel width Link to comment Share on other sites More sharing options...
Bicyclemech1 Posted June 7, 2013 Author Share Posted June 7, 2013 To drop the WRX springs on to my good LGT struts, WRX top hats are necessary. Rear spring rate for wagon is 190lbs. WRX wagon springs are close enough to do the job? Thanks to the forum for the speedy responses. This is cool. G.. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted June 7, 2013 Share Posted June 7, 2013 No. WRX rear struts range from between 119 lbs/in and 144 lbs/in. That's quite a large difference. It also will cause the rear of the wagon to sit much too low. The front WRX springs are all 163 lbs/in (up from 132 lbs/in on your car currently) and will drop the front around 0.5" and the rear will need 3/8" spacers to bring it back up and even the height out. This will dramatically change the handling of your car.. For the worse in my opinion... Now, for the big problem... You can't put any rear WRX springs on OE Legacy rear struts. The spring is too wide. Fronts are only 2mm wider and might fit. Also, you'll have to match rear springs to top hats of the same year (02/03 springs to 02/03 top hats and 04-07 springs with 04-07 top hats). You can mismatch springs to any year WRX strut from 02-07. Also, to keep the camber and all alignments as close to the Legacy as possible, it is optimal to use WAGON struts from a WRX. Link to comment Share on other sites More sharing options...
Bicyclemech1 Posted June 8, 2013 Author Share Posted June 8, 2013 There really isn't a combination from another car or generation that works REALLY well with the Wagon. H&R no longer makes wagon specific springs. Nor does anyone else I can find Eibach for the WRX looks pretty good in regards to spring rate, but requires the strut swap too... Sticking with my solid stock suspension is looking better all the time:rolleyes::rolleyes::rolleyes: Link to comment Share on other sites More sharing options...
Zues Marine Posted June 8, 2013 Share Posted June 8, 2013 just throw on some coilovers Link to comment Share on other sites More sharing options...
Bicyclemech1 Posted June 8, 2013 Author Share Posted June 8, 2013 The spring rates are horribly stiff for my application. I would appreciate a link to coilovers with DD spring rates Link to comment Share on other sites More sharing options...
Kennyfvholla Posted June 8, 2013 Share Posted June 8, 2013 You won't find anything... Alright.... So... What you're considering DD spring rated are actually quite low. The average sporty DD car these days has around 200 plus lb/in at least, in the rear. Tein's H-Techs for WRX struts will give you a brilliantly smooth ride with plenty of sportiness to the handling. Stock WRX springs are WAY too soft. Link to comment Share on other sites More sharing options...
monkeyposeur Posted June 9, 2013 Share Posted June 9, 2013 I have H&R springs, I wonder what the spring rates are on them?!? Link to comment Share on other sites More sharing options...
