teamafx Posted May 31, 2013 Share Posted May 31, 2013 I have a horrible idle, severe misfire and when in drive or reverse would almost stall out. Changed turbo Swapped Injectors with known good out of my 04 Subaru XT New Headgaskets New Timing Belt New Spark Plugs New head, all valves adjusted Still had misfire. Tore engine down, found ringland failure on 3 cylinders, had engine reworked, new pistons, rings, etc. Misfire at idle is now gone. Put in gear and the idle is solid, even with a/c idle is solid. Drive under light pedal acceleration, all ok. Drive with any acceleration and misfire goes from 1-4 on autel scan tool, but triggers misfire codes in cylinder 2, and cylinder 4. Once off of throttle the misfires disappear. Any ideas? When drivi Link to comment Share on other sites More sharing options...
rob-2 Posted May 31, 2013 Share Posted May 31, 2013 How is your PCV? You have a lot of oil in your TMIC? Link to comment Share on other sites More sharing options...
teamafx Posted May 31, 2013 Author Share Posted May 31, 2013 no oil in TMIC, idle is rock solid, just under a load.....im begining to think the valves werent adjusted properly causing the misfire on the same side. Link to comment Share on other sites More sharing options...
rob-2 Posted May 31, 2013 Share Posted May 31, 2013 You might be correct. Link to comment Share on other sites More sharing options...
RawrParts Posted June 1, 2013 Share Posted June 1, 2013 Have you change the fuel filter? Link to comment Share on other sites More sharing options...
JmP6889928 Posted June 1, 2013 Share Posted June 1, 2013 Check ignition coils. These cars eat them. Also check the plug that goes into the ignition coils. I had that problem and ended up having to put a slight twist on the pins in the coils to make sure they had good contact and the problem went away. Link to comment Share on other sites More sharing options...
