Corker999 Posted May 25, 2013 Share Posted May 25, 2013 My 99 SUS has had an intermittent starting issue for the last 18 months or so, sometimes when I turn the key to the crank position all I get is a click. So far I have replaced the starter and solenoid, these were new (not re-manufactured) parts, and the battery. Also, I can often get the car to start by either waiting an extended period of time (at least 30 mins) or sometimes by rapping my hand against the panel below the steering column right above the pedals. If anyone has any idea what I might need to do I would greatly appreciate the advice. The problem has been getting progressively worse and is beginning to wear thin on my nerves. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 31, 2013 Share Posted May 31, 2013 IMO you need to replace the key and ignition switch where the key goes in. Older Civic's had this problem too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Corker999 Posted June 3, 2013 Author Share Posted June 3, 2013 Thanks. I've recently come to that conclusion too. I was just looking to see if anyone thought it might be something else a little bit cheaper. But I guess if I have to spend the money, I have to spend the money. Thanks for the help. Link to comment Share on other sites More sharing options...
AZP Installs Posted June 28, 2013 Share Posted June 28, 2013 It could also be a loose connection in the ignition switch area as well. The only caveat is that you are getting a clicking, I'm assuming by the engine bay, when it won't start. This would indicate that the ignition switch is working. Have you replaced the ground and/or starter cables? -Mike Paisan AZP's First Private Track Event, June 19 at NJMP Thunderbolt $315 including Classroom and Mentor! http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
