urdrwho Posted May 24, 2013 Share Posted May 24, 2013 A quick question, does a 97 Subaru Outback 2.5 engine have a MAP sensor and if so where is it located. I can't think at the moment where it would be located, I know of the MAF but I didn't think that a MAF and MAP could be on the same engine. It is an automatic trans Link to comment Share on other sites More sharing options...
Zues Marine Posted May 24, 2013 Share Posted May 24, 2013 Pressure Selector Switch on the Pass side strut tower, brown plug(?) Link to comment Share on other sites More sharing options...
urdrwho Posted May 24, 2013 Author Share Posted May 24, 2013 Thanks. I'm thinking the same thing. The book just calls it a Pressure Sensor. It does adjust timing and I'm wondering about the inline filter to it. IT says I can attach a manual vac to it and see if there are changes to the engine. Pressure Selector Switch on the Pass side strut tower, brown plug(?) Link to comment Share on other sites More sharing options...
Zues Marine Posted May 24, 2013 Share Posted May 24, 2013 there should be a diagram of vacuum layouts in a sticker on the underside of your hood, over the fuse box.. should help you figure things out a bit better Link to comment Share on other sites More sharing options...
urdrwho Posted May 24, 2013 Author Share Posted May 24, 2013 Just for kicks I disconnected the vac line that is attached to the intake, the one that has a "T" and goes to the FPR and the pressure sensor setup. I expected an immediate CEL for the MAP. Didn't happen, so I went for a short drive. I expected to see a worse running engine. After all the FPR wasn't working and the MAP wasn't working, so something should go wrong. No worse running engine. Hm? In fact the idle may have been a bit less lumpy but I attributed that to the increased RPM's because the intake had un-metered air entering it. Came home stopped the car, hooked up my code reader, started the car and there was a CEL. Yep it was the MAP. So I hooked pulled the vac line off the FPR and expected to see some kind of difference but no, not one bit of difference. I pulled a vac on the FPR and it held. It just made me go hm?????? there should be a diagram of vacuum layouts in a sticker on the underside of your hood, over the fuse box.. should help you figure things out a bit better Link to comment Share on other sites More sharing options...
