starbai007 Posted May 21, 2013 Share Posted May 21, 2013 Exactly what the title says. I was in 4th for the pull as everyone recommends with a 6 speed manual, but wasn't quite able to get up to redline. Today was about 78 very humid/muggy in the morning. I've seen 15.7 - 16.4 psi on a regular basis, so i'm assuming the weather may have effected this run. https://docs.google.com/file/d/0B-l_KfToW9HOdjZMYVJuRUlvX0E/edit?usp=sharing Link to comment Share on other sites More sharing options...
eckseleven Posted May 21, 2013 Share Posted May 21, 2013 Your log has everything in one column. Could you fix it and upload again? Link to comment Share on other sites More sharing options...
acumenhokie Posted May 21, 2013 Share Posted May 21, 2013 Correct gear for 5th gen pull is 3rd (2k rpm to redline). It's really a 5 speed with an overdrive gear. NJ sells 93 octane gas right? Link to comment Share on other sites More sharing options...
DeltaSniper Posted May 21, 2013 Share Posted May 21, 2013 Make sure you dont have a boost leak first. Link to comment Share on other sites More sharing options...
starbai007 Posted May 22, 2013 Author Share Posted May 22, 2013 Actually hit the normal 16.5 this morning I really think its the warm weather. NJ sells 93 octane everywhere. Ill give 3rd a shot later tonight. Link to comment Share on other sites More sharing options...
