05sleeper Posted May 21, 2013 Share Posted May 21, 2013 *More logs on post #4* So I fixed my misfire and also fixed a leak coming from the BPV but noticed the PO had it on full hard so I loosened it a bit to get rid of the surge and the car runs sooo much smoother and actually wants to stay in boost between shifts rather then being super laggy but seams to have changed my learning values. I'm full bolt on minus bigger turbo and injectors. I'm protuned as well for 19psi. I can't seam to hit my target boost and running rich still (lc-1 reads mid-low 10's instead of the 11.1 it was tuned for) and from the looks of my a/f learning values I think I have an issue but I really don't know what they are supposed to be at. I've cleaned the MAF, replaced a/f sensor, I have no rear o2 sensor (was tuned without it). Hopefully someone can tell me some info from this log or any info on what else I should log. ThanksFixed misfire, Running Rich.csv Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted May 21, 2013 Moderators Share Posted May 21, 2013 Why does your log have so few rows for the pull? Do you have the fast polling option turned on? Also, can you pull a learning view and post it? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
05sleeper Posted May 21, 2013 Author Share Posted May 21, 2013 I have quite a bit of things that were supposed to log but I just did a quick third gear 3k to around 6k then stopped it but where is the fast poll option? And I'm using the access port to log so what would the learning view be? When i get out of training today I'll look at it again. Link to comment Share on other sites More sharing options...
05sleeper Posted May 22, 2013 Author Share Posted May 22, 2013 Here's 2 runs I did one day apart from each other and whats weird is the second one is running the correct AFR's that I was tuned for but still a little short of target boost and the first run is rich. Look at the learning values? I don't understand how it runs like this in Dallas but ALWAYS rich in Austin when everyone I've talked to that got tuned in Dallas doesn't have any issue coming back due to elevation or what not. And the hot and cold weather doesn't change a thing, it's got a mind of it's own and its finally starting to pissing me off.datalog2.csvCorrect afr's, little shy of target boost.csv Link to comment Share on other sites More sharing options...
05sleeper Posted May 23, 2013 Author Share Posted May 23, 2013 Now afr's are back to where they need to be today. Will probably change back to rich later or tomorrow since I'm going back to Austin haha ugh Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted May 25, 2013 Share Posted May 25, 2013 log IAT and see what it is. Link to comment Share on other sites More sharing options...
05sleeper Posted May 30, 2013 Author Share Posted May 30, 2013 ok I'll try to get a few logs very soon with the IAT in there Link to comment Share on other sites More sharing options...
05sleeper Posted June 4, 2013 Author Share Posted June 4, 2013 So don't have any logs yet but I had a suspicion that my Bpv hose was leaking from where it mounted to the inlet so I has a buddy who had a smoke machine and we hooked it up and sure enough it's pouring smoke out of that connection point. Good thing I have my nice silicone Bpv hose so I can put that on and clamp it. That was no doubt a cause to my rich issue now for the target boost. I was watching iat and if I sit to long it gets up to 153 degrees and when I try to boost it def hits lower so hopefully that's why and I just need to start weighing my options of front mount or not lol. I'll install the hose this weekend and reset ecu and let it learn again and see where that puts me, hopefully that will be the end of my gremlin Link to comment Share on other sites More sharing options...
