imfamousG Posted May 19, 2013 Share Posted May 19, 2013 So occasionally when I start my car it will come out the exhaust pipe? Sometimes it's more than others. Any ideas what it is and how to fix it? Link to comment Share on other sites More sharing options...
lgtvf52 Posted May 19, 2013 Share Posted May 19, 2013 What color is the smoke? Blue is burning oil. White is antifreeze. Sent from my SPH-L710 using Tapatalk 2 Link to comment Share on other sites More sharing options...
imfamousG Posted May 19, 2013 Author Share Posted May 19, 2013 I think it is white. Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted May 19, 2013 Share Posted May 19, 2013 That's the head gaskets. Oh boy... Link to comment Share on other sites More sharing options...
imfamousG Posted May 19, 2013 Author Share Posted May 19, 2013 If its blue is it like a light blue? And I don't think it's the head gaskets cuz I just got a new engine with new heads not that long ago Link to comment Share on other sites More sharing options...
Stang70Fastback Posted May 19, 2013 Share Posted May 19, 2013 Blue-tinted smoke means you are burning oil. Link to comment Share on other sites More sharing options...
lgtvf52 Posted May 19, 2013 Share Posted May 19, 2013 If its blue is it like a light blue? And I don't think it's the head gaskets cuz I just got a new engine with new heads not that long ago Even still it could be the head gaskets sometimes they just go for no reason also new motor does not mean that it will not burn oil or anything like that so u just have to look at the smoke carefully and see if it is white or tinted blue Sent from my SPH-L710 using Tapatalk 2 Link to comment Share on other sites More sharing options...
imfamousG Posted May 19, 2013 Author Share Posted May 19, 2013 I do believe it is blue tinted Link to comment Share on other sites More sharing options...
pleaidestar Posted May 19, 2013 Share Posted May 19, 2013 Your pcvs? Valve, lines and everything clear? Link to comment Share on other sites More sharing options...
spooln30 Posted May 20, 2013 Share Posted May 20, 2013 Usually if it smokes blue on start up then kinda goes away its the valve seals. But white smoke would lead to headgaskets. Link to comment Share on other sites More sharing options...
Sludgeroo Posted May 20, 2013 Share Posted May 20, 2013 If your pcv valve is clogged it wont let it vent and you'll get some mild blow by. If you see any seepage from the 2 breather lines on the valve cover it may be a clogged pcv. As with valve seals it slows as the engine heats up to operating temperature and small tolerances expand and seal. Link to comment Share on other sites More sharing options...
imfamousG Posted May 21, 2013 Author Share Posted May 21, 2013 it is blue tinted smoke just saw it a few minutes ago..... Link to comment Share on other sites More sharing options...
imfamousG Posted May 24, 2013 Author Share Posted May 24, 2013 How do I stop my car from burning oil? Link to comment Share on other sites More sharing options...
pleaidestar Posted May 24, 2013 Share Posted May 24, 2013 You got to narrow the problem down, think about where oil goes and where its contained. Oil goes throughout the motor, is contained to where its supposed to be by some thin gaskets, ingenuity and some rubber bits. You could have a 3 dollar pcv that is stuck all the way to piston rings letting some into the combustion chamber. Check your spark plugs out, they can tell you a lot about your motors health. Link to comment Share on other sites More sharing options...
