Xplosivo1 Posted May 15, 2013 Share Posted May 15, 2013 Hey all, I am in the process of replacing my motor and several other parts because I spun a bearing. I want to replace the up and down pipes in the process, can anyone tell me if I can run catless and still pass smog? Any reccomendations on what combination of up/down CBE etc... I also plan on upgrading to a 16g or 18g turbo if that matters any. Thanks. Link to comment Share on other sites More sharing options...
thisisthenewsic Posted May 16, 2013 Share Posted May 16, 2013 No way will you pass smog without a cat. Removing cats from a car is illegal and a federal offense also. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted May 16, 2013 Share Posted May 16, 2013 What do you think this is, America? This is California, you don't stand a chance. Best bet is to just slap the oem DP on since it's so easy. Link to comment Share on other sites More sharing options...
Xplosivo1 Posted May 16, 2013 Author Share Posted May 16, 2013 Thats what I figured, but wanted to make sure. Any suggestions on what combination I should use? Do they all perform the same? Link to comment Share on other sites More sharing options...
Scooter Posted May 26, 2013 Share Posted May 26, 2013 My Cobb HFC DP and Bosal STi UP passed CA smog twice. First time with stock catback and 2nd time with the Perrin mid-Y and stock cans. Old thread: http://legacygt.com/forums/showthread.php/stage-2-lgt-passes-ca-smog-77753.html Technically, the aftermarket DP/cat should have failed the visual inspection, but I don't think most techs look that hard. Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
Thourbow Posted May 28, 2013 Share Posted May 28, 2013 Technically, the aftermarket DP/cat should have failed the visual inspection, but I don't think most techs look that hard. This is true, you didn't really pass, the technician failed to find the modifications, and at the same time your risking your car being flagged and sent to a referee, which a referee is way more techincally suave than the monkeys doing SMOGs. Best thing to do is keep your stock parts, put those on for SMOGs and reinstall your go fast goodies after the smog. That is the fool proof method for Kalifornia smog, garenteed to pass. Link to comment Share on other sites More sharing options...
