NiteOwl561 Posted May 12, 2013 Share Posted May 12, 2013 So, are these wheels worth it? Ok, so I'm looking for new wheels to clear the '08 STi Brembo front and rears I just picked up. I found these local, (actually about an hour and a half drive) for around $400 cash. They are not new and one wheel definitely has some curb damage, I'd call it significant. The others have typical wear and tear from daily use. From what I can tell, there are no visible bends and structurally the look good. OZ Racing Supperlegera 5x100 18x8 +51 The damaged wheelies top right. Link to comment Share on other sites More sharing options...
NiteOwl561 Posted May 12, 2013 Author Share Posted May 12, 2013 Close up of the damaged wheel. Link to comment Share on other sites More sharing options...
NiteOwl561 Posted May 12, 2013 Author Share Posted May 12, 2013 Are these considered 18x8 or would the be 18x9? Link to comment Share on other sites More sharing options...
laz Posted May 12, 2013 Share Posted May 12, 2013 Why don't you look behind inside the wheel. There are usually markings telling you the specs of the wheel. X --- Link to comment Share on other sites More sharing options...
ShockerGT Posted May 12, 2013 Share Posted May 12, 2013 If they are +51 then it will be tight on clearance. My +48 18x8 Superleggeras are very close to my Brembos Link to comment Share on other sites More sharing options...
NiteOwl561 Posted May 12, 2013 Author Share Posted May 12, 2013 So any thoughts on if they are worth $400 with damage? I'm not concerned about weight reduction, as I don't track the car. I'm thinking it's better to get a brand new wheel that's a little more expensive than waste $400 on these. Link to comment Share on other sites More sharing options...
laz Posted May 12, 2013 Share Posted May 12, 2013 Only if you can fix them yourself or find a cheap way of fixing them. They are good wheels if the run true. I would make a $300 offer X --- Link to comment Share on other sites More sharing options...
Drift Motion Posted May 12, 2013 Share Posted May 12, 2013 If they are +51 then it will be tight on clearance. My +48 18x8 Superleggeras are very close to my Brembos you know offset has nothing to do with brake clearance right? easy way to find out is to see if they say these wheels will fit 04 STi Link to comment Share on other sites More sharing options...
LatentWagen Posted May 14, 2013 Share Posted May 14, 2013 Are these considered 18x8 or would the be 18x9? That wheel is 18x8... they are measured from inside of the lips, where the tire would seat. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
O.C.D. Posted May 15, 2013 Share Posted May 15, 2013 Close up of the damaged wheel. File down the rough parts and then make sure you prep well. grab some JB weld and then apply liberally. Wait to dry and then sand down to smooth. Prep/paint/clear, done. Easy to fix. $400 is not bad at all for those wheels. Link to comment Share on other sites More sharing options...
mhoran89 Posted May 15, 2013 Share Posted May 15, 2013 File down the rough parts and then make sure you prep well. grab some JB weld and then apply liberally. Wait to dry and then sand down to smooth. Prep/paint/clear, done. Easy to fix. $400 is not bad at all for those wheels. If it can't be fixed with duck tape or superglue then break out the JB Weld. Link to comment Share on other sites More sharing options...
O.C.D. Posted May 15, 2013 Share Posted May 15, 2013 If it can't be fixed with duck tape or superglue then break out the JB Weld. Hell's yes! Link to comment Share on other sites More sharing options...
Chameleon Posted May 15, 2013 Share Posted May 15, 2013 I have seen the results of a JB Weld refinished rim and was very impressed ... Link to comment Share on other sites More sharing options...
Spec B Posted May 15, 2013 Share Posted May 15, 2013 BTW - these will not clear brembos without a spacer. Link to comment Share on other sites More sharing options...
ShockerGT Posted May 20, 2013 Share Posted May 20, 2013 you know offset has nothing to do with brake clearance right? easy way to find out is to see if they say these wheels will fit 04 STi BTW - these will not clear brembos without a spacer. Interesting Link to comment Share on other sites More sharing options...
