Zues Marine Posted December 21, 2013 Share Posted December 21, 2013 are we talking about the fronts or rears now? Link to comment Share on other sites More sharing options...
LegGtBK97 Posted December 21, 2013 Share Posted December 21, 2013 are we talking about the fronts or rears now? Front Control arms Link to comment Share on other sites More sharing options...
monkeyposeur Posted December 22, 2013 Author Share Posted December 22, 2013 Still haven't installed them. I don't have a garage and its winter so they will wait until warmer conditions. I think I was misinformed about the sway bar mounts being different. I looked at a bunch of GCs, Bds, and BKs at the salvage yard and they all look identical to me. Same angle, everything. So I think they will swap on as is. The 5mm hubs are necessary for the wheels to clear the 4 pots in the front. Otherwise I wouldn't need them. I'm getting H&R spacers when I do the install. The SS brake lines that came in the 4 pots have been cut so I can't reuse them. That's why I will get new brake lines later. Link to comment Share on other sites More sharing options...
Zues Marine Posted December 22, 2013 Share Posted December 22, 2013 front gc8s CAs fit the bk. idk about the rears Link to comment Share on other sites More sharing options...
monkeyposeur Posted December 22, 2013 Author Share Posted December 22, 2013 I have the rears too so we'll see when it warms up, lol. Link to comment Share on other sites More sharing options...
LegGtBK97 Posted December 23, 2013 Share Posted December 23, 2013 front gc8s CAs fit the bk. idk about the rears It would have to be from an N/A impreza correct Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted December 24, 2013 Share Posted December 24, 2013 are we talking about the fronts or rears now? I'm talking rears. Link to comment Share on other sites More sharing options...
SBT Posted December 24, 2013 Share Posted December 24, 2013 The rear hub housing (28411AA01 Alternate) is the same between the 2nd Gen BD/BG/BK, but the rear lateral link is not. L/BK = 28411AA010 GT/BD/BG = 20255AA310. CG8 = 20255AA310 Check the numbers to be sure. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted January 1, 2014 Share Posted January 1, 2014 And there we have it. Being the the rear of the BD is set up to be a sedan probably. Link to comment Share on other sites More sharing options...
SBT Posted January 1, 2014 Share Posted January 1, 2014 The rear of the L/BK is setup to be drum brakes (30th Anniversary L - sedan and wagon - being the exception) - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Jdmlegacygtb Posted May 17, 2021 Share Posted May 17, 2021 I have a link on the gc8 aluminum control arms they fit well? That sway bar mount is bd legacy? Link to comment Share on other sites More sharing options...
