xt2005bonbon Posted May 6, 2013 Share Posted May 6, 2013 As the title says, do I need to break in my engine after the heads got refreshed? The short block has been left alone except for the oil pick up tube (changed with a killerb). If I need to break it in, what procedures should I follow? Car has 63K. Parts changed: -8 valve lifters -most of the gaskets from the full gasket kit (including valve stem oil seals) -oil pick up tube -TOB (TSK3) -spark plugs -both filtered banjo bolts If I need to break it in, that would kinna suck cause I just put some fresh 5w40 fully synthetic Shell oil in the car. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 6, 2013 Share Posted May 6, 2013 No. That was was. It's not like you got new rings. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted May 6, 2013 Author Share Posted May 6, 2013 Awesome . Link to comment Share on other sites More sharing options...
