Scubaru03 Posted April 25, 2013 Author Share Posted April 25, 2013 If i just do a catless up pipe on my 05 lgt will i need a tune? Everyone tells me to eliminate that cat asap. I dont have funds right now for new dp and turbo and all the other goodies. Link to comment Share on other sites More sharing options...
iNVAR Posted April 25, 2013 Share Posted April 25, 2013 If i just do a catless up pipe on my 05 lgt will i need a tune? Everyone tells me to eliminate that cat asap. I dont have funds right now for new dp and turbo and all the other goodies.If you're doing the work yourself and have the time, then go ahead and do it. No tune should be required. But if you're paying someone else to do it, you may want to hold off if you plan on getting the turbo and DP in the near future because the labor is the same. You have to pull the DP to get to the UP. Link to comment Share on other sites More sharing options...
Scubaru03 Posted April 25, 2013 Author Share Posted April 25, 2013 Yeah i was going to do myself. Ive read about a resistor that i have to install to eliminate and egt (i think its called)? Where do i install that and where can i get it radioshack? Thank you Link to comment Share on other sites More sharing options...
iNVAR Posted April 25, 2013 Share Posted April 25, 2013 do a search here for resistor. should come right up. Link to comment Share on other sites More sharing options...
Scubaru03 Posted April 25, 2013 Author Share Posted April 25, 2013 do a search here for resistor. should come right up. Yeah i found a great walkthrough on it. Am going to do in 2 weeks. Got a 10' sti up pipe. Just need some gaskets and im set. Thank you. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 25, 2013 Share Posted April 25, 2013 Yeah i was going to do myself. Ive read about a resistor that i have to install to eliminate and egt (i think its called)? Where do i install that and where can i get it radioshack? Thank you Tell the guy you want a 2.2k ohm resistor. the package has 5 in it for $1.25 Stick one in the connector the EGT connector comes out of. Its that simple. Oh the Tuner will cancel the CEL too. So remove it when the car gets tuned. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
goneskiian Posted May 7, 2013 Share Posted May 7, 2013 16G is a great street turbo. Definitely needs a tune though. May not be a "real" turbo in some people's eyes but is plenty fun to get you into trouble! So I've heard. Link to comment Share on other sites More sharing options...
Alex609 Posted May 7, 2013 Share Posted May 7, 2013 def need a tune Link to comment Share on other sites More sharing options...
