ResidentRedneck Posted April 18, 2013 Share Posted April 18, 2013 i need a clutch. so im ordering it now. question is, are the flywheel-to-crank bolts, and the pressure plate bolts re-useable? i know some cars are torque to yield. Link to comment Share on other sites More sharing options...
Osei Posted April 18, 2013 Share Posted April 18, 2013 All bolts on the Suby are reuseable. O. Link to comment Share on other sites More sharing options...
ResidentRedneck Posted April 18, 2013 Author Share Posted April 18, 2013 awesome, thank you! Link to comment Share on other sites More sharing options...
4doors4hp Posted April 24, 2013 Share Posted April 24, 2013 ehhh i would say thats debatable that all are re-usable. the head bolts in the engine are torque-to-yield. Your turn them down to 50lbs, then back them up a few times, and they ultimately end up around 65-78lbs. They stretch. wouldnt re-use. some re-use them, but its safer to just spend the $40 on bolts.. Link to comment Share on other sites More sharing options...
BadTrainDriver Posted April 24, 2013 Share Posted April 24, 2013 The bolts you're referring to are find to reuse. Link to comment Share on other sites More sharing options...
Osei Posted April 24, 2013 Share Posted April 24, 2013 ehhh i would say thats debatable that all are re-usable. the head bolts in the engine are torque-to-yield. Your turn them down to 50lbs, then back them up a few times, and they ultimately end up around 65-78lbs. They stretch. wouldnt re-use. some re-use them, but its safer to just spend the $40 on bolts.. Inaccurate. The head bolts are not TTY. Subaru doesn't replace them when doing HG's, nor do they say it is mandatory. This "issue" keeps coming up ever so often, but they are not TTY. see:http://www.ultimatesubaru.org/forum/topic/122596-2003-engine-and-what-i-have-learned/?hl=%2Btorque+%2Byield#entry1033921 O. Link to comment Share on other sites More sharing options...
