User Name Posted April 11, 2013 Share Posted April 11, 2013 A few days ago I discovered that my RR tire was flat, and took it in to Tires Plus. The tire had a nail in it, and was patched. Everything was peachy. The drive home I started to notice a strange noise from the same wheel. Almost like I had picked up another nail. Sounded quite nasty, especially on decel, whether or not the clutch is engaged or not. Sort of like a hum, or the sound of a jet engine powering down. Definitely speed dependent. Took it to the same place and they recommended the Hub Assembly be replaced. Which sounded perfectly acceptable to me. But I ended up driving it home after much debate. Then proceeded to drive it another hundred miles before the night was over. Anyway, is this common? It's my first AWD car and I'm very unconfident in making any diagnosis. PS. If you tell me to use the "Search" function, go jump off a bridge. Thanks! Link to comment Share on other sites More sharing options...
Max Capacity Posted April 11, 2013 Share Posted April 11, 2013 These cars are known for the rear hubs going bad as well as the fronts. My left front went first. What year is yours ? You can drive a long time before the bearing is really bad, but if you can hear that clearly yours is ready to go. Most of us hear a low hum for a long time, the hum will change as you take corners at highway speeds. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
.blackgt. Posted April 11, 2013 Share Posted April 11, 2013 How many miles are on your car? I believe Subaru began to warranty the wheel bearings up to 100k? Someone please correct me if I am wrong. Link to comment Share on other sites More sharing options...
Lucid Posted April 11, 2013 Share Posted April 11, 2013 Rear wheel bearings on 2005 and early 2006 Legacy and Outback received extended warranty coverage for 8 years/100k miles. TSB 03-58-08. Link to comment Share on other sites More sharing options...
